20 Most Recent Frigidaire FAFW3574KA Front Load Washer Questions & Answers
Will not wash
motherboard of the unit may be defective
12/25/2013 3:46:03 PM • Frigidaire... • Answered on Dec 25, 2013
2answers
My Frigidaire Affinity washer makes a loud buzzing sound when you push the start button and will not start, what can I do
Good Morning Anonymous, this is Z. I am happy to assist you! I understand that your door indicates it is open and your dryer will not operate. Let's attempt resetting your dryer by either unplugging it or flipping the household circuit breaker off. It is good to wait approximately ten minutes and turn on your dryer. Select a normal cycle and verify if your dryer will start. If your dryer will not operate then it possibly have a faulty door lock assembly or a communication problem with the control board. At this point, it would be advisable to contact an experienced appliance repair tech to assist further.
3/20/2024 3:24:35 AM • Frigidaire... • Answered on Mar 20, 2024
Frigidaire Front Load washer (25 yrs old) fills completely but does not spin for the wash cycle. Manual timer clicks and buzzes but drum does not spin nor does the timer advance.
Sure sounds like your timer has bit the dust. I'm not sure if the timer is still available. You have a great washer there. Good luck.
2/11/2024 4:24:20 PM • Frigidaire... • Answered on Feb 11, 2024
My Frigidaire FWAC 19B5MSGNW washing machine won't move on from the spin cycle. The light is on and if I fill it up with water it will pump out the water but the spin light will not come off.
The machine does not exist as you have written it. There are two likely reasons The door switch has failed and hasn't passed the self test procedure. or the control board / timer has failed. Try power cycling it. Remove the mains plug for an hour. It is has an On Off button press it for a minute. For a knob, full it and leave two minutes. Plug back in and try again. https://www.google.com/search?q=Frigidaire+FWAC+19B5MSGNW ..
1/2/2024 11:12:23 PM • Frigidaire... • Answered on Jan 02, 2024
Frigidaire front load washer door locked
crowbar?
5/15/2023 1:33:24 PM • Frigidaire... • Answered on May 15, 2023
What's stopping my dryer from running continuously
Hi, Please power cycle your dryer and attempt to run it again. If this fails, please ensure that your clothes are evenly distributed so that they weight of the clothes doesn't cause the dryer to be shutdown. Just to double check, please ensure that you've cleaned the lint track of your dryer. Lastly, you can use an power outlet extender to help switch the power outlet that you're using to run your dryer as there might be something wrong with your current one. Thank you.
1/8/2023 1:32:57 AM • Frigidaire... • Answered on Jan 08, 2023
My Frigidaire dryer won't run longer than 5 secs what's wrong how can I fix
There could be several issues that could cause your Frigidaire dryer to stop running after just a few seconds. Here are a few potential problems to consider:
  1. Thermal fuse: The thermal fuse is a safety device that shuts off the dryer if it overheats. If the fuse has blown, the dryer will not run.
  2. Clogged dryer vent: If the dryer vent is clogged, it can cause the dryer to overheat, which could trip the thermal fuse.
  3. Faulty cycling thermostat: The cycling thermostat regulates the dryer's temperature. If it's faulty, the dryer may not run for more than a few seconds.
  4. Faulty start switch: If the start switch is faulty, it could prevent the dryer from running.
  5. Faulty door switch: The door switch prevents the dryer from running when the door is open. If the switch is faulty, the dryer may not run.
To fix the problem, you'll need to diagnose which of these issues is causing the problem and then replace the faulty part. I recommend having a mechanic diagnose and fix the problem for you.
1/8/2023 1:18:38 AM • Frigidaire... • Answered on Jan 08, 2023
3answers
WHAT IS E11 ERROR CODE IN MICROWAVE FRIGIDAIRE
The E11 error code indicates a problem with the gas sensor DE32-60011A and or the wire harness DE39-40678D. Unfortunately the manufacturer has discontinued the sensor. You may want to try contacting local parts dealers, one of them might still have it in stock. Enter your part number in a search engine, a smaller company might have it or try eBay, Amazon or similar sites . Search by using the manufacturers part number. Try a used appliance store, sometimes they have the same model or a usable part for your machine.
12/23/2022 7:33:43 AM • Frigidaire... • Answered on Dec 23, 2022
My Frigidaire Washer, ATF8000FE1, won't run.
Try power cycling it. Disconnect from the mains supply for 5 minutes and plug back in. Try again. If that doesn't fix it, you need a service call.
10/31/2022 9:06:10 PM • Frigidaire... • Answered on Oct 31, 2022
Frigidaire washer dryer Model FFLE4033QWO; dryer door is locked closed
Hi, Please attempts to use oil to help gently open the door . Or you can start the machine and attempt to open the door then. Running the machine might free up the lock somehow. Thank you.
9/29/2022 8:13:46 PM • Frigidaire... • Answered on Sep 29, 2022
2answers
Frigidaire GLTF2940ES 27 Inch Front-Load Washer. The softener dispenser will not drain. It has been cleaned.
Question edited for clarity. Question moved to Frigidaire. Normally, you have to remove the top of the siphon. Cleaning the tray often doesn't work. Or you can remove the drawer, turn it over and run hot water into the hole until it clears.
9/25/2022 5:34:21 AM • Frigidaire... • Answered on Sep 25, 2022
2answers
My frigidaire washing machine displays E11 error and stops before completing washing cycle. How can I trouble shoot? I plugged and unplug it didn't help
On many machines the E11 error occurs as one or more of these connecting wires break, this may be due to excess movement from unbalanced loads. To prevent this when washing any heavy items ensure there are enough heavy items to spread around the drum to help the machine balance its load.
9/25/2022 5:33:23 AM • Frigidaire... • Answered on Sep 25, 2022
2answers
Frigidaire Washer GLTF2940FS1 is Stuck on Temperature Control
bad temp sensor
8/26/2022 5:22:43 AM • Frigidaire... • Answered on Aug 26, 2022
Frigidaire model MEX731CAS3 washer uses hot water instead of cold on the cold cycle
You have the hoses hooked up wrong. Reverse them.
8/14/2022 9:19:46 PM • Frigidaire... • Answered on Aug 14, 2022
Frigidaire FAFW3574KA Front Load Washer Logo
2 questions posted
Top Frigidaire Washing Machines Experts
ZJ Limited
ZJ Limited
Mike Cairns
Mike Cairns
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Frigidaire Washing Machines
Most Popular Question
will not wash
  • Washing Machines
