Here is a list of issues that are common
https://www.samsung.com/uk/support/model/WD0804W8E1/XEU/
but you may need a replacement control panel now.
If water/liquids ingressed the control board or a bad connection on the board has happened, that is another probable cause.
Question edited for clarity.
Check the water inlet solenoid. It sounds like it has failed. It should open and let the water in from an instruction from the controller..
https://www.google.com/search?q=Samsung+WW80v9+no+water
Check the Door Latch and Alignment:
Ensure that the door is completely shut and latched. Sometimes, clothing or debris can get caught between the door and the latch, preventing proper closure. Make sure there's nothing obstructing the door.
Inspect the door seal for any damages. A damaged seal might not allow the door to close securely.
Child Lock Feature:
Samsung washers come with a child lock safety feature. If the child lock is engaged, it prevents accidental start of the wash cycle.
Check if the child lock is activated. If so, disable it and try running the wash cycle again.
Motor Control Unit (MCU) Inspection:
Visually inspect the Motor Control Unit (MCU) board for any burned spots. The MCU is located on the left side behind the lower access panel.
If you find burnt spots on the MCU, it might be the cause of the issue. You can order a replacement MCU if needed.
Other Troubleshooting Steps:
Reset the washing machine by unplugging it and then plugging it back in after a few minutes.
If the problem persists, consult a technician to inspect the lock mechanism or control board.
Is this the flexible pipe coming out of the back of the machine or the pipe work inside the machine? The flexible pipe (usually grey in colour) is a 'push on' fit. You'll need to get in behind the machine. With a bit of wiggling and twisting the pipe should pull off at the machine end. You should then be able to get the whole thing out from behind the machine to clean it. I used an long, old piece of wood dowel to loosen the dirt. I then carefully flushed it through using a garden hose with the nozzle set to jet, not to the wide spray pattern. I know this because I got very wet making that mistake.
Contact your honeowner's insurance company and see if that damage is covered. I don't think any reputable company would advise 'reclaiming' parts of a cleaning device that sat in raw sewage.
I have a problem with the Samsung WA80U3 washing machine. The safety stop button is activated and I cannot cancel it even though I tried to press the water level + function for more than 5 seconds and there is no solution. Please help.
Question edited for clarity and add Maker.
Question moved to maker category.
It appears to be a known issue with these. I could put a couple of pints of CLR descaling solution in the bottom and leave it overnight. CLR is made for Calcium, Lime and RUST.
Samsunghttps://www.samsung.com > ... > Home Appliance
Aug 10, 2023 - This "black particles" will sometime disconnect themselves from the bowl during washing cycle and they will contaminate your just washed clothes ...
Missing: WA13F5S2 ' Show results with: WA13F5S2
