20 Most Recent Samsung WF405ATPAWR 27" Front-Load Washer 4.0 cu. ft. Capacity, 15 Questions & Answers
WHAT DOES THE CODES MEAN
cold b door inter lock
2/28/2015 9:25:02 AM • Samsung... • Answered on Feb 28, 2015
2answers
MY Samsung washing machine WD0804W8 ECO BOBBLE not working
Here is a list of issues that are common https://www.samsung.com/uk/support/model/WD0804W8E1/XEU/ but you may need a replacement control panel now. If water/liquids ingressed the control board or a bad connection on the board has happened, that is another probable cause.
4/19/2024 10:41:38 AM • Samsung Washing... • Answered 13 hours ago
Does not take water after weight of loading clothes. Samsung WW80v9 top loader diamond drum checked water inlet filter, dirty, clean and replaced. Start machine, does the start up, but no water intake
Question edited for clarity. Check the water inlet solenoid. It sounds like it has failed. It should open and let the water in from an instruction from the controller.. https://www.google.com/search?q=Samsung+WW80v9+no+water ..
3/28/2024 6:40:46 PM • Samsung Washing... • Answered on Mar 28, 2024
Add garment light won't go off when Samsung front loader locks. Stops cycle from beginning - Samsung front loader model #WF42H5000AW/A2
Check the Door Latch and Alignment: Ensure that the door is completely shut and latched. Sometimes, clothing or debris can get caught between the door and the latch, preventing proper closure. Make sure there's nothing obstructing the door. Inspect the door seal for any damages. A damaged seal might not allow the door to close securely. Child Lock Feature: Samsung washers come with a child lock safety feature. If the child lock is engaged, it prevents accidental start of the wash cycle. Check if the child lock is activated. If so, disable it and try running the wash cycle again. Motor Control Unit (MCU) Inspection: Visually inspect the Motor Control Unit (MCU) board for any burned spots. The MCU is located on the left side behind the lower access panel. If you find burnt spots on the MCU, it might be the cause of the issue. You can order a replacement MCU if needed. Other Troubleshooting Steps: Reset the washing machine by unplugging it and then plugging it back in after a few minutes. If the problem persists, consult a technician to inspect the lock mechanism or control board.
3/10/2024 9:13:14 PM • Samsung Washing... • Answered on Mar 10, 2024
How to fix a Samsung SW674ASP washing machine that won't drain. I have already tried cleaning the filter.
Question edited for clarity. It won't be anything to do with the filter. It is either the motor controller, the capacitor or the control board. It need professional diagnosis. https://www.google.com/search?q=Samsung+SW674ASP+washing+machine+that+won%27t+spin ..
2/6/2024 4:45:16 AM • Samsung Washing... • Answered on Feb 06, 2024
Drain pipe clogged in samsung sr606-ev - how to clean it/ unclogged?
Is this the flexible pipe coming out of the back of the machine or the pipe work inside the machine? The flexible pipe (usually grey in colour) is a 'push on' fit. You'll need to get in behind the machine. With a bit of wiggling and twisting the pipe should pull off at the machine end. You should then be able to get the whole thing out from behind the machine to clean it. I used an long, old piece of wood dowel to loosen the dirt. I then carefully flushed it through using a garden hose with the nozzle set to jet, not to the wide spray pattern. I know this because I got very wet making that mistake.
1/28/2024 3:09:42 PM • Samsung Washing... • Answered on Jan 28, 2024
2answers
How do I clean a Samsung washing machine after sewage backflowed into it?
Contact your honeowner's insurance company and see if that damage is covered. I don't think any reputable company would advise 'reclaiming' parts of a cleaning device that sat in raw sewage.
1/12/2024 4:32:42 PM • Samsung Washing... • Answered on Jan 12, 2024
2answers
I have samsung washing machine WA80U3 model with drain problem
I have a problem with the Samsung WA80U3 washing machine. The safety stop button is activated and I cannot cancel it even though I tried to press the water level + function for more than 5 seconds and there is no solution. Please help. img20240107183222-udqdjzn4arxyysthdzlpgixn-d-0.jpg
1/8/2024 2:18:23 AM • Samsung Washing... • Answered on Jan 08, 2024
2answers
Samsung Washer won't fill.
Check the lid switch. Some models will not start washing if it detects that the lid is open.
1/4/2024 12:06:34 AM • Samsung Washing... • Answered on Jan 04, 2024
Samsung WA12V5 washing machine. How to fix buttons for being unresponsive to program.
Try a power reset. Disconnect from the mains socket. Wait 15 minutes. Press and hold Power Button for 1 minute. Plug back in. https://www.google.com/search?q=samsung+wa12v5+unresponsive ..
1/2/2024 5:20:37 PM • Samsung Washing... • Answered on Jan 02, 2024
Samsung Steam Aqua Jet VRT. I bought this machine used. I Don't have an owner's manual. The access panel is not in the front lower side. It's not on the either side either.
Question edited for clarity and toss in some CAPS. The all have alpha numerical model numbers. I think it is this one. What type of 'access panel' are you looking for? https://images.webfronts.com/cache/frdvahdqyvrv.pdf https://www.google.com/search?q=samsung+steam+aqua+jet+vrt ..
12/29/2023 1:40:25 AM • Samsung Washing... • Answered on Dec 29, 2023
My Samsung WA10B7Q1 Spins but doesn't agitate
check under agitator possible bad gears or cogs
12/8/2023 9:15:36 PM • Samsung Washing... • Answered on Dec 08, 2023
Samsung WA13F5S2 Top Load Compact Washer. It has black flakey residue found on clothes after final rinse?
Question edited for clarity and add Maker. Question moved to maker category. It appears to be a known issue with these. I could put a couple of pints of CLR descaling solution in the bottom and leave it overnight. CLR is made for Calcium, Lime and RUST.
CLR Calcium, Lime and Rust Remover
CLR Brands https://clrbrands.com > Products > CLR-Household Get rid of stubborn lime, calcium, and rust stains effortlessly with our powerful all-in-one cleaner. Visit CLR Brands now for sparkling, spotless surfaces. ‎Where to Buy · ‎See all Videos · ‎How To Clean a Showerhead
Top loader washer has black particles on clothes
Samsung https://www.samsung.com > ... > Home Appliance Aug 10, 2023 - This "black particles" will sometime disconnect themselves from the bowl during washing cycle and they will contaminate your just washed clothes ... Missing: WA13F5S2 ‎' Show results with: WA13F5S2
Solved: Samsung Washer - Residue (All Types)
Samsung https://us.community.samsung.com > td-p Sep 8, 2020 - 1 Solution · Remove all items from the washer tub and ensure the tub is empty. · Press Power to turn on the washer. · Turn the Cycle Selector to ... ‎Sign in ' Samsung account · ‎Search icon · ‎Page 4 Missing: WA13F5S2 ‎' Show results with: WA13F5S2
My top loading, Samsung washing machine is leaving black
JustAnswer https://www.justanswer.com > Appliance Repair Aug 5, 2019 - Typically the black flakes come from crust build up on the upper line inside the tub between the inner basket and outer basket. There is a ... 1 answer · Top answer: The site will give an additional option to speak by phone which you can ignore if you want. ... Missing: WA13F5S2 ‎' Show results with: WA13F5S2.. https://clrbrands.com/Products/CLR-Household/CLR-Calcium-Lime-and-Rust-Remover
11/16/2023 12:52:45 AM • Samsung Washing... • Answered on Nov 16, 2023
2answers
I have a Samsung dv48h7400ew/a2 it powers on but won't start
Make sure the door switch is being activated . If it does not latch properly unit will not function.
11/6/2023 10:18:19 PM • Samsung Washing... • Answered on Nov 06, 2023
Samsung eco bubble washer and dryer continues to fill with water till the top. Could it be that the sensor is not working?
If your Samsung Eco Bubble washer is filling with water till the top, it could be due to a faulty water inlet valve 1. You may need to replace the valve to get your appliance filling with water and working properly again . However, if you suspect that the sensor is not working, you can try the following steps : Check if the LED on the eco bubble wash button is on. Check if there is too little laundry in the washing machine. In case of heavily soiled laundry, bubbles may not be generated very well. Unplug the machine from the mains to ensure your safety. Locate the two screws on the back of the machine that hold the top cover in place, and unscrew them. Gently push the top cover back and remove it to expose the interior. Take out the detergent container. Identify and remove the screws that secure the front panel in place. If none of these steps help, please contact a local Samsung service center
10/28/2023 5:34:03 PM • Samsung Washing... • Answered on Oct 28, 2023
Where can I find Samsung washing machine parts here in Bataan?
Samsung Phillipines or the three Samsung Support Stores shown https://www.google.com/search?q=Samsung+washing+machine+parts+in+Bataan ..
10/11/2023 3:27:57 AM • Samsung Washing... • Answered on Oct 11, 2023
Samsung WF405ATPAWR 27" Front-Load Washer 4.0 cu. ft. Capacity, 15 Logo
1 questions posted
Top Samsung Washing Machines Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Samsung Washing Machines
Most Popular Question
codes mean
  • Washing Machines
