20 Most Recent LG Dryer Main Control Board - EBR36858801 Questions & Answers
Clif,
Almost all dryers have thermal protection in redundancy to prevent fires. This includes a thermostat, thermal fuse, and high limit switches, normally in the back of the dryer. Gas or electric. If any of these fail you wont run. But, if it is an electric dryer, you MUST have 220VAC at the outlet. 110VAC to ground on each leg dont cut it. if your qualified, measure between the two legs for 220.
If you need further help, reach me via phone at https://www.6ya.com/expert/steve_24d988f3507f7480
LG Dryer Main... | Answered on Oct 12, 2013
Turn breaker off. Then try again, this might reset controller.
LG Dryers | Answered on Apr 16, 2019
I'm guessing the drive belt is incorrectly installed. It needs to hold the tightening pulley at tension. The belt goes down from left of drum to clockwise around the pulley them around the drive motor. Push up on pulley to install. Answer if you need more info. Only way to do this is to take it all apart again. You may be able to leave the fron roller assembly on to reach around it. Good luck.
Type it in on internet and there is a video on youtube how to get at it.
Well obviously check that you have power to outlet, make sure completely plugged in, then take top off(if front loader) and check connections to control board.
LG Dryers | Answered on Apr 04, 2019
Wash your filter with dish liquid and hot water. The oil in dryer sheets and fabric softener blocks the mesh.
Also check the outside vent is operating correctly and is not blocked.
Whereas is says 'clean filter', the error message is triggered through lack of airflow.
https://www.google.com/search?q=LG+Gas+Dryer+5988W+error+is+check+filter
LG Dryers | Answered on Mar 14, 2019
Cooling light indicator doesn't go off until dryer shuts off
LG Dryers | Answered on Feb 27, 2019
Try washing your lint filter with dish liquid, and water and give it a gentle brush. It has been identified that dryer sheets cause a waxy build up which restricts air flow.
LG Dryers | Answered on Feb 13, 2019
Probably a damaged or defective door latch.
LG Dryers | Answered on Feb 09, 2019
You have problems in the dryer, call for service.
LG Dryers | Answered on Jan 29, 2019
yes it is possible that element is bad, before I started throwing parts at it would check hi limit disc. Also if you have 3 wire a 240 will read 240 between the hot wire and from neutral or ground 120. 120 will measure 120 between neutral.
LG Dryers | Answered on Jan 23, 2019
LG Dryer Main Control Board - EBR36858801 Logo
2 questions posted
Top LG Dryers Experts
jimorris77
Craig Butler
Craig Butler
Marvin
Marvin
Are you a LG Dryer Expert? Answer questions, earn points and help others
View Most Popular
LG Dryers
  • LG Dryers
Most Popular Question
dryer main control board ebr36858801
  • Dryers
