20 Most Recent Singer 7470 Confidence Sewing Machine Questions & Answers
I have a Singer Confidence 7470.
Is the top (right side) thread getting caught up below the needle plate?
Likely you need to increase tension. The elastic will tend to grab the top thread so a higher tension may be necessary.
A larger diameter needle may help.
7/9/2022 10:23:56 AM • Singer 7470... • Answered on Jul 09, 2022
Hi, I have a singer confidence 7470 sewing machine and the needle keeps hitting the bottom of the bobbin. I need to know how I can adjust the needle.
Try a brand new needle. If the old one is bent, that could be why it is striking. If the new needle doesn't resolve the issue, the machine most likely has a timing issue. You can search for multiple web sites and videos for discussions and instructions for sewing machine timing issues. Or you can take it for service. ...
10/4/2016 7:45:17 PM • Singer 7470... • Answered on Oct 04, 2016
My sewing machine jammed the fabric into the bobbin case and now it won't sew the needle hits the plate under the bobbin case can I adjust this myself
Here are some videos that may help. If not, search the internet for thread jam. How to Fix Thread Jam Sewing Machine When Thread is Caught in Sewing Machine Sewing Lessonshttps://www.youtube.com/watch?v=tDcBUR0PcyAIf you get it unjammed, be sure to install a new needle as the old one is probably damaged. If there are still issues, the machine's timing may be off and would need professional service.
10/23/2015 5:26:48 PM • Singer 7470... • Answered on Oct 23, 2015
I bought my machine last yr & just started using it 2 days ago. Now it's acting up? The needle is hitting the bobbin plate. I've notice this is a common thing to happen to other confidence owners.
Sounds like the needle is bent. If it hits the plate just once it will blunt the needle and not sew properly. Failing that, the machine's timing may be off. Was it shifted about a lot in the year it was left in the box?
4/18/2015 10:17:09 PM • Singer 7470... • Answered on Apr 18, 2015
The letter stitches are stitching on top of each other
1-800-4-SINGER (1-800-474-6437)Monday through Friday, 8:00 a.m. to 4:00 p.m. C.T.
11/13/2014 5:02:26 PM • Sewing Machines • Answered on Nov 13, 2014
My Singer sewing machine model #7470 keeps stitching after I remove my foot from the pedal.
Mine was doing the same thing. I called Singer and if the reverse stitch is working fine, it's a problem with the foot pedal. They sent me a new one under warranty. If the reverse stitch is having issues as well, then it could be a problem in the machine itself.
2/28/2013 3:42:25 PM • Singer 7470... • Answered on Feb 28, 2013
Can I use a vintage singer 161103 zigzagger attachment on a 201 k machine?
No I don't think it will. That attachment is for a 'Slant Shank' machine like a 301. The K on the Sewing machine model number simply means it was built in Scotland. That means it is basically the same as most other 201's.
4/16/2024 5:14:24 PM • Singer Sewing... • Answered 3 days ago
Singer Futura CE 150. I bought a used carriage unit attachment for it and the it drags really hard. It won't move at all while on the machine or when I take it off. Is there a way to fix it? Thanks
Question edited for clarity. Do you mean the embroidery unit. If it is secondhand and has been stored for a long time, sewing machine oil, or worse WD40 goes 'gummy'. You would need to clean all the out. WD40 is a good solvent, so spray, leave it to soak, spray again and agitate with a brush. The wash it all off with hot soapy water. Dry thoroughly and after a few days, lubricate metal parts with sewing machine oil and any plastic parts with a dry silicone spray like Jigaloo. Test Jigaloo on a flat piece of plastic first as it is also a powerful fast drying solvent.
Embroidery Unit, Singer #052007
Sewing Parts Online https://www.sewingpartsonline.com > products > embroi... Guaranteed to fit Singer Sewing Machine Models: CE-150 Futura III, CE-250 Futura III, CE-350 Futura III, SES1000 Futura III, SES2000 Futura III. Free · ‎ In stock https://www.google.com/search?q=Singer+Futura+CE-150+carriage+unit ..
4/15/2024 12:19:18 AM • Singer Sewing... • Answered on Apr 15, 2024
Singer Curvy flashing lights
I cannot see a question. Please include a question.
3/21/2024 8:00:29 AM • Singer Sewing... • Answered on Mar 21, 2024
Free manual for singer 8618
check if machine is threaded properly
3/8/2024 10:31:28 AM • Singer Sewing... • Answered on Mar 08, 2024
I have a singer quantum stylist 9980. When I turn it on, it beeps as usual but does not do the needle adjustment. It will not sew at all. How do I fix that?
  1. In the event that your Vocalist Quantum Beautician 9980 isn't playing out the needle change and won't sew, there could be a few issues. To begin with, guarantee the machine is strung accurately, and the bobbin is appropriately embedded. Check in the event that the needle is embedded accurately and not harmed. On the off chance that the issue continues, counsel the client manual for investigating tips or consider reaching Artist client assistance for additional help.
2/12/2024 1:57:13 AM • Singer Sewing... • Answered on Feb 12, 2024
Singer 7470 Confidence Sewing Machine Logo
9 questions posted
Top Singer Sewing Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Singer Sewing Machines
Most Popular Question
  • Sewing Machines
