20 Most Recent
Hobart FP150 Food Processor Questions & Answers
Hobart grinder mdl 4346, what is the value the
It is a thermistor and the value should be approximately 100k ohms at room temp.
You can substitute a pair of 100k ohm resistors to allow operation but to actually get the protector board to function as designed you will need the ~100k ohm thermistor with the correct temp / resistance curve bonded into the stator.
An option would be to use a standard motor starter for the protection although the wiring gets a bit tricky with the relays, aux switches and the reversing contactor.
Another option would be to imbed / affix a klixon type overload into the windings and wire this in series with your 100k ohm resistor.
This will still allow the board to indirectly protect the motor.
Hobart slicer 1612 need to make the product
Hi, I just received an older 1612 Hobart, and fixed the same problem.
First i disassembled the linkage from the bottom, then i used a propane torch to heat the rods and the aluminum castings (carefully, bring the temp till it is hot to the touch) Hammering doesnt work well so i made a piece of pine appx 1x1" with a notch to use as a pry stick. put a thin piece of plywood against the casting so you dont crack the housing, as it is thin alum.
Worked for me, take your time
How to Order Food on Train?
To order food on a train, you can use various online platforms like IRCTC e-catering, RailRestro, or local vendors available at specific stations. Simply provide your train details and select your preferred meal options through their websites or apps.
