20 Most Recent Movado 800 Performance watch Questions & Answers
The cover on the back or inside of the back typically they don't have serial numbers just model numbers.
Thank you hope this helps
Movado 800... | Answered on Jun 05, 2016
It is likely you need to take it to be repaired.
There is some small piece of metal or grease that clutches when the watch is in your wrist.
A good watch repair service will do the job.
Www.tictacarea.com
Movado 800... | Answered on Apr 22, 2014
Yes, the Movado is a self winder, and it was designed for the sports active wearer, of which the motion of the wearer's arm provides the power to keep the watch wound. Apparently you are not active enough for the watch to be fully wound, so when you take it off, it will use up all of the stored energy in the spring and stop. many self winders will only store enough energy for 8-12 hours of use and will require constant wearing. You could try wearing it to sleep and see if this is enough to keep it wound.
If you feel that this is not the case for your watch, then you may want to have it looked at by a watch maker
Movado 800... | Answered on Feb 11, 2012
Try this site. I have the same watch and the instructions are avaialable from the Movado support site: http://service.movadogroup.com/movado/
Movado 800... | Answered on Jun 27, 2011
That watch has a quartz movement and most likely needs a new battery. Take it to a jeweler or to Sears for the replacement. It only takes a few minutes and should coat about $10.
Movado 800... | Answered on Mar 13, 2011
Turn the crown of the watch towards you until it pops out... After the crown pops out, pull on it to extend fully and you should be able to change the time at that point
Movado 800... | Answered on Mar 08, 2011
Movado 800 Performance watch Logo
38 questions posted
Top Movado Watches Experts
Arturs Kalnins
Arturs Kalnins
Marvin
Marvin
Are you a Movado Watch Expert? Answer questions, earn points and help others
View Most Popular
Movado Watches
  • Movado Watches
Most Popular Question
movado 800 series sub 200
  • Watches
