20 Most Recent Pro-Fit Pro.Fit Ns 50 00 Infiniti I30 /I35 & Nissan Maxima 00 Up Questions & Answers
If it ticks when you try to start it it's your starter and it will have to be taken out and rebuilt or you will have to purchase a new one I always have them rebuilt generally it will vary on the cost depending on the make and model I generally order my parts from eBay because parts stores have a really big mark up hope this helps Merry Christmas
Pro-Fit Pro.Fit... | Answered on Dec 07, 2017
Sounds more like the throttle position sensor.
Pro-Fit Pro.Fit... | Answered on Apr 27, 2014
The only thing your battery light and your brake light have in common is your battery and alternator. This happened to me and my battery was low because my alternator went bad. I suggest taking it to autozone (if there is one near you). They can test it for free.
Pro-Fit Pro.Fit... | Answered on May 10, 2012
Easiest way is to go to the junk or auto salvage yard, find your car and get a fuse box door. Some places will let you have it for free. Sometimes you can even find the owners manual.
Pro-Fit Pro.Fit... | Answered on Feb 19, 2011
The problem is with the valve or the circuit. First take off the valve connect a 12V source and blow into one of the holes, air should flow freely. With the 12V source removed air should not pass.
With a voltmeter check the valve's connector voltage, it should not be 12V.
The valve generally remains closed, it opens during testing.
Pro-Fit Pro.Fit... | Answered on Dec 30, 2010
if it's a homelink garage door opener, on many models you simply press the program button on the back of your garage door opener (the big noisy thing hanging in the middle of your garage), and then within 30 seconds press the desired button on your i30 garage door opener.
Your owners manual should have details about the process.
Pro-Fit Pro.Fit... | Answered on Jun 11, 2010
Watch "My Cousin Vinny", although it is some old country saying, it runs true. The vibrating is from the tire being off balance. Just take it to a tire sotre and they should be able to correct the issue easily. Another possible answer could be a bent rim. Have that checked out as well.
Pro-Fit Pro.Fit... | Answered on May 20, 2010
check your starter...that is a very common issue
Pro-Fit Pro.Fit... | Answered on May 05, 2010
Run the stereo system through the fuse panel. It will disconnect the power when the key is off.
Pro-Fit Pro.Fit... | Answered on Aug 12, 2009
try stepping on the brake and the clutch all at the same time it could be a safety feature which will let you start the car
Pro-Fit Pro.Fit... | Answered on Aug 07, 2009
Make and model may help you get an answer.
Car Audio &... | Answered Yesterday
it looks as though you are using the wrong code
The radio SERIAL NUMBER is required for a code
First remove the radio from the dashboard.
Then post the radio make+model plus all the letters+numbers on any labels,barcodes or stamped in the metal casing.
This information can then be used to see if a code can be calculated
Further useful removal information can be found here CLICK HERE
Car Audio &... | Answered 2 days ago
Pro-Fit Pro.Fit Ns 50 00 Infiniti I30 /I35 & Nissan Maxima 00 Up Logo
25 questions posted
Top Pro-Fit Car Audio & Video Experts
greg benton
Craig Butler
Craig Butler
Are you a Pro-Fit Car Audio and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Pro-Fit Car Audio & Video
Most Popular Question
im trying dl fuse diagram i30 1996
  • Car Audio & Video
