Hi, Problem may be with your drive or playback software.
Solutions:
1. Copy your media from your DVD disc to your harddisc and then try playing it (not directly from DVD drive). If media plays well, then there can be problem with your drive.
2. If still play back jumps after copying the DVD to your computer, then the problem might be with your system. Download and install VLC media player from the link.This should fix the proper due to codec and playback.
I hope this is helpful in solving your problem. Thanks
There is no mention of Dual Layer support in any specifications I can find about this recorder. DL media is a very nice plus, so if it supported it, I imagine it would figure prominently in marketing and on the drive tray, too. All this tends to make me believe that while it offers some nice features, DL media is not one of them.
The LG site turned up little about the drive, but I did find some sales info below:
Full 'make model (what it is)' in all questions please, first 3 words.
Capacitors can split or bulge, resistors can burn,, the transformer can fail internally..
Take it for repair unless you have the thousands of dollars of test equipment and have do the 2 year electronic course.
A communication error has occurred between the outdoor and indoor units. Faulty wiring or a malfunctioning control unit may be responsible. Contact LG customer service for assistance. Their number is 1 800 243 0000.
You will need to connect a single HDMI cable from your sound bar to the HDMI ARC or the HDMI eARC port on the Roku T.Make sure that both of the devices are both turned on.When your TV detects the sound bar,it will then automatically initiate the setting up process. Lastly follow the easy on screen instructions to finish setting up the connection.
If your LG 55UM7300PUA is not powering on, there are a few things you can try to troubleshoot the issue. 1. Check the power cord and make sure it is securely connected to the TV and to the wall outlet. 2. Check the wall outlet to make sure it is working properly. Try plugging in a different device to the outlet to make sure it is providing power. 3. Check the power button
