20 Most Recent
Sears Craftsman 17196 10 amp Corded Orbital Reciprocating Saw Questions & Answers
I can't find the blade lock used to remove my old
There should be a small black button on the right side of hand grip. You can also use a small block of wood between the blade teeth and the shoe to hold the blade in place while you loosen the blade nut.
6/29/2020 12:01:30 AM •
Sears Saws
Answered
on Jun 29, 2020
How to replace safety start switch on tablesaw
Another magnetic switch could be made to work. Grainger may be the place to look for one of these. You will likely have to modify the mounting and to some extent the wiring.
1/2/2019 9:01:38 PM •
Sears Saws
Answered
on Jan 02, 2019
Manual for #103.0205 circ. saw
Earlier comment 103.0205 Table Saws does not need lubrication is simply wrong.
The103.0202, 103.0203, 103.0305 Craftsman Companion Table Saws main Arbor axle DOES have to lubricated or else the axle bearing will quickly loosen side-to-side or vertically and fail to provide accurate saw cuts.
FWIW, Sears no longer sells Arbor Axle replacement parts... The Table Saw Arbor axle and Bearing Housing cannot use sealed bearings unless the saw case is re-milled and extensively modified. There are 2 Oil Hole Plugs (part# 475-32) that need to be opened and oil applied so the Arbor axle shaft does not get scored or worn.
I use 30wt motor oil to relube the Arbor Axle Shaft depending on amount of use, temperature, and axle rotation stiffness.
Remember, the higher the RPM speed of the table saw motor and/or the longer the use, the more frequently you may need to relube the Arbor Axle Bearing!
3/6/2016 2:36:23 AM •
Sears Saws
Answered
on Mar 06, 2016
Wrong direction
You very well may have put the blade on backwards or the saw has been wired wrong. Should spin counter- clockwise to draw the saw down to the wood when cutting
12/10/2013 10:52:08 PM •
Sears Saws
Answered
on Dec 10, 2013
