20 Most Recent Uniflame FG2204C Grill Questions & Answers
You may be turning the gas tank on too fast. Turn handle very slowly and then wait at least a minute before lighting burners.
Uniflame FG2204C... | Answered on Dec 02, 2017
take it back for a refund as it is not fit for the purpose
Uniflame FG2204C... | Answered on Jul 06, 2017
Child proof Mode:
To leave child proof mode: Press the up arrow button twice and Down arrow button once. The unit will send out 3 beeps and the indicator in the LCD panel that shows that the child proof is on will disappear.
Uniflame FG2204C... | Answered on Dec 08, 2013
Hi boltbucrayfa...
I think your culprit is the gas regulator valve...
If it is not working properly then it will not deliver the proper amount of gas to the burners.
Check all your burners to make sure they are not plugged...
The when you are outside away from Flames and ignition sources.
Remove the hose from the grill...open the gas to the grill (you have the hose off the grill) and listen to the flow of gas...if it is very low then there is your problem.
You can shut off the flow of gas, then tap the gas regulator on the sides, top and bottom lightly with a hammer and then turn back on the gas to see if the gas flow increased...if it did, then shut off the gas and rehook up the gas line to the grill..and your good to go grilling again.
Some gas regulators have an adjustment under the removable cap.
If the gas flow did not increase, the replace the gas regulator
Please take time to rate me
Uniflame FG2204C... | Answered on Sep 26, 2011
To solve this problem, first be sure you have adequate gas in the tank. If that checks out OK, do the following:
1. Turn the gas tank valve OFF and disconnect the hose from the tank.
2. Wait 5 minutes and reconnect the hose to the tank.
3. Open the tank valve VERY, VERY SLOWLY (Slow motion, slow).
4. Once the tank valve is fully open, light the burner farthest from the tank first and set the burner
control knob on HIGH. Does the flame height look correct for being set on HIGH? If so, light
the remaining burners the same way. Do all the burner flames look correct? If so, you solved
the problem. Remember, to always open the tank valve Very, Very Slowly.
If that didn't solve the problem, you will need to replace the grill's Hose/Regulator Assembly. It runs about $30.00 at any home center or hardware store that sells grills & accessories. If you replace it, turn the tank valve ON Very, Very Slowly.
Hope this helped you to troubleshoot and solve the problem. Happy Grilling and thanks for choosing FixYa.
Uniflame FG2204C... | Answered on Jul 23, 2011
I'm going to make a wild assumption here, and that's when you attempt to light the grill, you push in and hold a gas release button when you first hit the ignitor. I'm also going to presume taht you can hear gas hissing when you do this. If you can't hear the hissing, you have a blocked jet. Presuming that you can, and that you can probably get the grill to light if you stand there like an idiot, holding the button in all day, then read on (If I'm way off base, please add a comment on the thread and I'll get back to you).
This is probably a faulty safety cutout. When you light the grill, the flames heat a temperature sensor that, once hot, increases the pressure in the sensor's copper pipe and opens a safety valve to allow gas to continue to flow (It's made like this so, if your flame gets blown out, the sensor cools and cuts off the gas supply, making it safe from gas leaks). These sensors occasionally fail, and very sensibly "Fail safe" - No pressure in the sensor pipe, the valve won't open and there is no gas to the burner.
If you take a look inside the grill, where the burner is, you will see the sensor, usually the bit that is in the flame is cylindrical, about an inch long made of metal about 3 or 4 mm thick, tapering at the end. It will be held in place by a nut that fits on a thread at the base of the sensor. Running from the sensor is a copper pipe that runs to the cutoff valve. Unbolt the sensor and withdraw it from the hole it is mounted in, trace the copper pipe back to the valve (where it is usually screwed into the valve with a 10mm connector that looks like a car brake pipe connector. Unbolt from the valve. These sensors are widely used on most gas appliances (Boilers, gas fires, cooker hob burners and patio heaters all use the same kind of sensor). You should be able to get a replacement from any gas appliance service agent. If you go into a shop, take it with you. The only thing you need to do is make sure the replacement you get is long enough. If you are offered one that is slightly longer, that
Uniflame FG2204C... | Answered on Jul 22, 2011
The problem may lie with the grill's regulator and the way the tank was turned ON.
To solve this problem, do the following:
Hope this helped you to troubleshoot and solve the problem. Happy Grilling.
Uniflame FG2204C... | Answered on Jul 15, 2011
Betty, to solve this problem, do the following:
Uniflame FG2204C... | Answered on Jul 09, 2011
If the grill lights, but the flames are low, try replacing the hose and regulator.
Uniflame FG2204C... | Answered on Jul 05, 2011
Bob, your wife is partially correct. However, both burners should have blue flames with orange tips. Cleaning the burners and the their venturi valves, should solve the problem. When I say cleaning them, I mean removing and cleaning them.
Hope this helped you and Happy Grilling!!
Uniflame FG2204C... | Answered on Jun 28, 2011
Michael, please see my previous response to your question/problem. Submitted 6/6/11 @ 5:50pm ET.
Uniflame FG2204C... | Answered on Jun 06, 2011
You probably do anything directly wrong. First, make sure you have adequate gas in the tank.
if you do, turn the tank valve OFF and disconnect the hose from the tank. Wait 5 minutes and reconnect the hose to the tank. Turn the tank valve ON VERY, VERY, SLOWLY (Slow motion, slow).
Once the tank valve is fully open Light one burner and turn it to it;'s highest setting. Has the flame eight returned to normal? If so, light the remaining burner and turn it to high. Do both flame heights look normal. If so, you solved the problem. Remember to always turn the tank valve ON very, very slowly.
If that didn't solve the problem and you had enough gas in the tank, you will need to replace the grill's hose/regulator assembly. You can purchase one at any home center or hardware store that sells gas grills and accessories. It runs about $30.00. Take your old one with you for comparison purposes.
Hope this helped you troubleshoot and solve the problem. Happy Grilling!!
Turn the tank valve OFF. Disconnect the hose from the tank and wait 5 minutes. Reconnect the hose to the tank and turn the tank valve On VERY, VERY SLOWLY (Slow Motion, slow). Once the tank valve is fully open, light the burner and turn it to the highest setting. Do the flames appear to be correct for the highest setting? If so, you've solved the problem. Just remember to always turn the tank ON VERY, VERY SLOWLY.
If that didn't solve your problem, the grills regulator is permanently locked up. You will need to replace the hose/regulator assembly. You can purchase one at any hardware or home center store that sells gas grills. Take the old one with you for comparison purposes.
Hope that solved your problem and Happy Grilling!!
Uniflame FG2204C... | Answered on Mar 20, 2011
the regulator may be defective..this is the round metal object that is on the supply hose..they are available from home depot/menards..etc...
Uniflame FG2204C... | Answered on Jan 23, 2011
Check pressure regulator. It's the piece on the gas hose after the tank.
Uniflame FG2204C... | Answered on Sep 17, 2010
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Uniflame FG2204C... | Answered on Sep 05, 2010
There is a rpoduct calle GOO GONE that will remove anything...
But...
If it was me I would just turn the gas grill to hi fire "CLEAN" mode and burn it off. This will clean and santitze the new grill at the same time also..
Heatman101
Uniflame FG2204C... | Answered on Aug 02, 2010
Try replacing the hose and regulator, easy to do and inexpensive.
Uniflame FG2204C... | Answered on Jul 13, 2010
Uniflame FG2204C Grill Logo
63 questions posted
Popular Products
Top Uniflame Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
limabeenie
Level 1 Expert
Are you an Uniflame Grilling Expert? Answer questions, earn points and help others
View Most Popular
Uniflame Grilling
  • Uniflame Grilling
Most Popular Question
uniflame grill may clog somewhere
  • Grilling
