Troubleshooting & Support for
5,183 people viewed this product
hi, i have a jamo 250 sub.the blue light is working.when i connect the jack to the left line IN acc...
Well it would void the warrantee, but you can take the back panel off and the power supply will only hav...
If the subwoofer has its own power cord seperate from the rest of the audio system, the internal amp...
I WOULD LIKE 2 NO IF I CAN RESET MY PASSWORD 4 KLH SURROUND SOUND SYSTEM. I BOUGHT AT A SALE AND THE...
Hi,Try a 2.2 MF 50V cap should do the trick.Otherwise I have seen this problem before.You just nee...
The unit has to be opened and checked for blown or bulged capacitor.If that is all ok then yes the tra...
Contact the seller and the shipper and have it replaced. You wont be happy unless you do. You will alw...
What is the make and model of speaker? Are they powered or stand alone. IF they are powered by a plu...
Like I said run audio through the USB ,RCA ,3/8 audio and the 5/8 audio ports if you get audio it is the...
I doubt there is a way to put an RCA jack into that sub. All the input comes from the wireless boa...
The wattage listed on the speakers is the peak wattage the speakers are rated to handle. You need amp...
The outputs on that amplifier can't use that cord, you need another car audio amp then you can hook the...
Sub woofers are just mono amps. They feed both the right and left output together. So all you need is ...
Will any user manual suffice, or do you have a particular make and model in mind?
Have a tip for Jamo SUB300BA SUB 300 Powered Subwoofer Subwoofer?
how do I replace torn speaker mesh on sealed Jamo i300 subwoofer??
bowing 800ma with shorts reading across primary of power supply
Have a Jamo SW 410e subwoofer, 2 wires got pulled off the circuit board and I dont know where the...
looking for the service / repair manual for Jamo Sub300
I have a Jamo 250 powered subwoofer to be connected to my Pioneer vsx920k receiver. could you tell...
My Jamo subwoofer got no power as I plug in to power supply.
no power passing through jabo sub woofer, appears to have occurred after big storm here in perth...
My Jamo SUB 300 does not power up. There is power at the input power cord. However, no 120V AC power...
| Key Features | |||
| Full Product Name | Jamo SUB300BA SUB 300 Powered Subwoofer Subwoofer | ||
| Cabling | Cable | ||
| Speakers Function | Subwoofer | ||
| Technical Features | |||
| Frequency Reponse | 28 Hz - 150 kHz | ||
| Components | |||
| Woofer Size | 10" | ||
| Subwoofer Power | 300 Watt | ||
| Design | |||
| Mounting | Bookshelf | ||
| Outdoor/Indoor | Indoor | ||
| Dimensions | |||
| Depth | 20 in | ||
| Height | 14.9 in | ||
| Width | 12.2 in | ||
| Weight | 41.7 lb | ||
