20 Most Recent
Jl Audio 450/4 Car Audio Amplifier Questions & Answers
How do you bridge the jl audio 450/4
Nice amplifier. However it is best suited for speakers and not for sub woofers.
Connect the plus (+) from speaker output 1 and the minus (-) from speaker output 2.
Connect the plus (+) from speaker output 3 and the minus (-) from speaker output 4.
Now the amplifier is in bridge mode, which will give you 300 WATT RMS at 4 OHM load.
If you are bridging the amplifier to run sub woofers then do not forget to set the X- Over to LPF on the channels that you are planning to bridge. Whatever you do, make sure that the load you are asking the amplifier to play is no lower than 4 OHM. Playing this amplifier in bridged mode lower than 4 OHM is a recipe for trouble.
dreamsystems
Low Ohm Light
ohms are impedance or the amount of current being blocked through the line. The lower the ohms the less resistance. Speakers run at a certain ohm (or at least are recommended to run at). Have you bridged your amp? Usually when you bridge your amp it lowers the ohms by half. You may have damaged something, especially if you bridged your amp and didn't bridge it properly.
