20 Most Recent
Chevrolet 2011 Chevrolet Cruze LTZ Questions & Answers
Have a Chevy Cruze 2011, engine will crank but want start?
www.
cruzetalk.com/forum/25-service.../2239-darn-thing-
wont-
start.html
Jun 1, 2011 - 10 posts - 8 authors
Just had it in there two weeks ago because the "check engine" light stayed on ... Silly suggestion, but worth checking anyway: is the key bent in any way when ... I have a2011 Cruze, with about 12,000 miles on it. Two days ago I went into a store, and when I came out it wouldn't start... no crank ... nothing.
Thread: Cruze won't start, electrical / battery problem ...
Jun 26, 2014
Thread: 2011 Cruze starting problem
Jun 8, 2013
Starting Problems
Apr 14, 2012
Thread: Will not start!
Nov 26, 2011
More results from www.cruzetalk.com
www.ssrfanatic.com/forum/f5/
cranks-
but-
will-not-
start-52824/
I need a head valve seat for central pneumatic 21 degree angle framing nailer model 60828 also need headvalve seat for 34 degree angle finish nailer 68020
I have not been able to purchase replacement parts for these nail guns , however, have repaired them using parts from Bostitch framers and or just make the part. If the seal fits over the top of the cylinder, then try using seal from Bostitch framer part #N70155 fits a bit tight but works. Heat with a hair dryer to soften and install. If the seat is incorporated within the head valve, just dig it out and replace it with liquid two part urethane. Just mix and pour it in. After cleaning out the old seal, place head valve on level surface and pour in the mixed urethane till slightly over full to give the seal a nice crown. The finish nailer might also be repaired using other brand of seals. Remove the old part and take it to service center for a possible match. Good luck with your repair.
What oil should I use in Handiair H8/25 Compressor?
Many air compressors use a mineral blend or a synthetic oil, such as synthetic hydrocarbon, polyol ester or polyglycol. It is important to use a lubricant specifically rated for air compressors; do not use a general-purpose motor oil used for automotive or other purposes.
Read your user manual for more information.
