20 Most Recent
Hunter 30200 \ 30010 (Set) Air Purifier Questions & Answers
Model 30216. Need instructional
hi
Lee Taylor book from folowing link it's PDF book you can downlod
www.natcom.org/nca/files/.../2006%20Program%20(Full).pdf
Wont run after I cleaned it
On the model 30200 there is a safety interlock switch actuated by a plastic tab (about 4" down from the top of the front filter cover) on the right side. Assuming that all you did was take off the front cover and clean or replace the filter(s) and the unit was working previously, this should be your answer. If in taking off the cover the switch actuation tab was broken off, you could (carefully) wedge a tab into the slot where the switch resides. This defeats the safety aspect of certifying that the unit isn't running when you remove the cover. The safe work-around is to unplug the unit before you open it for service.
Air purifier HUNTER 30200
I hope this is not to late. This is an old post. But I have this same air cleaner. It does prove difficult at first to open and it feels like you are going to break it.
On the sides about two to three inches down is a large indentation. Slide your fingers in there and gently but firmly pull the face plate of the air cleaner off. The air cleaner is as big as the front of the air cleaner. It will slide right out. I hope this helps.
My hunter 30890 air purifier wont turn on after filter change
Most times the cover has an interlock. Look for something prijecting from cover and the a place where this would fit into. Align cover then close. If you dont see one then look under or behind filter. Also check the filter is installed correctly (direction of airflow). Remove power (unplug or circut breaker) then power back on might reset as well.
