20 Most Recent Dewalt DG7000 Heavy-Duty 7000 Watt Gas Generator Questions & Answers
3answers
Output voltage adjustment
Output voltage is based on 3600 rpm @ 60Hz. Sounds like your generator is over speeding slightly. Put a Frequency meter on the output of the generator and tune it to 61.5 Hz, that will get your generator in the 3600 RPM range.
1/3/2023 7:36:19 AM • Dewalt DG7000... • Answered on Jan 03, 2023
I have a Dewalt DG7000 pull start generator that puts out 75v on the 120v what could be the problem
could be the circuit breaker on the generator
1/19/2013 7:56:15 PM • Dewalt DG7000... • Answered on Jan 19, 2013
DEWALT model de 0077. I need diagrama schematic motherboard Dewalt model de 0077
No 'model de 0077'. All question must have FULL 'make model (what it is)'. https://www.google.com/search?q=dewalt+model+de+0077 ..
4/13/2022 5:14:21 PM • Dewalt... • Answered on Apr 13, 2022
Dewalt DG7000E stalls out whenever switch set to 240v. (with or without load) Runs fine and powers things with the 120V setting and plugs. Any ideas?
It might be one of the following: 1. Voltage changeover selector switch has blown - check if the power is still there before it enters the switch and still there after it leaves. 2. Breaker has failed on that leg - test before and after to see if working correctly 3. The plug socket has failed - Look for burn marks where wiring enters. 3. There is a fault in the alternator - see 2nd video down on this page for testing:https://www.generatorguru.com/help-me-fix-my-generator-repair-advice/ Hope this helps you. If you need more advise please contact us on our website www.generatorguru.com. We are always happy to help. Kind regards The Generator Guru Team www.GeneratorGuru.com gg_pic5black_adwords_1200x1200small-u42hrofub43isob1vkbjdq4v-5-14.jpg Generator Guru
10/29/2018 4:30:15 PM • Dewalt... • Answered on Oct 29, 2018
2answers
I just bought a Dewalt thickness planer and it keeps blowing out my circuit breaker,....which normally works fine and is 15 amps, which matches the rating for the planer. Can this be fixed?
It should be used on a 20 amp circuit. the 15 amp is the maximum your circuit will deliver. on startup it may exceed the limit. also your circuit may or may not deliver the power for a sustained time. do not use extension cord small than 12 gauge
8/6/2018 9:56:29 AM • Dewalt... • Answered on Aug 06, 2018
How do I find the serial number on my Dewalt 1800-watt portable power station for future warrenty and repairs?
https://www.dewalt.com/en-us/support?productsku=DCB1800B
8/3/2018 1:45:46 PM • Dewalt... • Answered on Aug 03, 2018
2answers
How do I unseiz my dewalt DG6000 generator motor due to non use
Remove spark plug. Pour a small amount of a lubricant like Marvel Mystery Oil in and allow to soak for a day or two. Repeat this process at least two times. Then try to turn the engine over slowly by hand. Do not use the pull rope or starter. You need to use a wrench, pry bar, etc. You may have to remove the engines cover to access the flywheel to turn it.
10/7/2016 11:03:53 PM • Dewalt... • Answered on Oct 07, 2016
2answers
Will only run for 10- 15 min. then shuts off.
You might have a thermal issue with the ignition coil shutting down after it gets warm. Happens.
9/25/2015 10:47:39 AM • Dewalt... • Answered on Sep 25, 2015
Gas in oil on dewalt generator
It's your carburetor. You'll have to clean it out, rebuild it, or buy a new one. The float pin is getting stuck so it's either the float or dirt inside. Make sure you turn the gas off after each use of your generator or it will eventually happen if there's dirt in the tank. Don't forget to change out the oil before you start it again or you'll have fireworks.
5/28/2015 12:10:28 AM • Dewalt... • Answered on May 28, 2015
My dewalt dg4300 runs but no power at recepticals
check connections
5/14/2014 5:21:47 AM • Dewalt... • Answered on May 14, 2014
0answers
0answers
0answers
Dewalt DCB101
Be the first to answer 3/23/2014 3:29:31 AM • Dewalt... • Posted on Mar 23, 2014Be the first to answer
0answers
Fuel solenoid
Your carburater is probably stuck open. The linkage on it is kind of flimsy. I have had to clean many mouse nests out of many machines. Look it over and check to see if the butterfly valve linkage on the top is moving with the speed adjuster.
12/15/2013 5:21:12 PM • Dewalt... • Answered on Dec 15, 2013
Dewalt DG7000 Heavy-Duty 7000 Watt Gas Generator Logo
2 questions posted
Top Dewalt Electrical Supplies Experts
Stan Ford
CJ Rock
CJ Rock
Al Taqah Al Sareeah...
Level 1 Expert
Are you a Dewalt Electrical Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Dewalt Electrical Supplies
Most Popular Question
output voltage adjustment
  • Electrical Supplies
