20 Most Recent Lanzar Optidrive OPTI500.2 Car Audio Amplifier Questions & Answers
How many watts does the lanzar optidrive 500.2 push out
250w x2 @ 4 ohm, 450w x2 @ 2 ohm, 900w x1 @ 4 ohm:D
4/26/2012 7:15:05 PM • Lanzar Optidrive... • Answered on Apr 26, 2012
I have two lanzar max 8 pro subs and a 1000 watt koiller amp what is best way to wire these components
Depends entirely on the output impedance of the amplifier and of course if it matches your loudspeakers.
11/19/2022 8:30:42 AM • Lanzar Car Audio... • Answered on Nov 19, 2022
2answers
I need to wire 2 12" DVC Lanzar MAXP124D to an 8 ohm load. Had it wired at a 2 ohm setting and it would over heat my amp. So tried to wire it to 8 and it wouldn't work. Need help.Thanks.
Your 8ohm channel is fried why happened was you ran 2 12s in an 8ohm load and turned it down to 2ohms the speakers was pulling all the power and that made it over heat and when it over heated it fried you're amp. It ain't no good you can't fix that
9/20/2021 11:09:00 PM • Lanzar Car Audio... • Answered on Sep 20, 2021
2answers
Hello my Lanzar 2000 watt amp started blowing its fuse I didn't know what the problems was and now my 4/12s wont play and my green power light wont come on ,how can I fix this amp or problem
When an amplifier causes trouble or otherwise stops working, it is necessary to eliminate external possibilities such as a short circuited output. If nothing external is causing the problem, unless you have a good friend who is an electronics engineer, it will be a repair shop task...
4/27/2020 4:43:46 PM • Lanzar Car Audio... • Answered on Apr 27, 2020
2answers
Why my lanzar pro 15 not making any sound...My wires& are good even have a perfect ground still no sound what so ever...
Check your fuses. Check to see if any of the wires are loose. Could be a blown fuse or loose wire. Possibly the following link might be of interest: https://www.youtube.com/watch?v=xMbsieEj0UM
3/15/2019 11:35:52 AM • Lanzar Car Audio... • Answered on Mar 15, 2019
How do you wire a lanzar maxp124d to amp.
have diagram of any sort?
1/12/2018 9:15:06 PM • Lanzar Car Audio... • Answered on Jan 12, 2018
Lanzar maxp104d I lost the paper on how to wire the speaker itself idk how to do it
https://youtu.be/1icfF0r30ls
3/16/2017 12:34:55 AM • Lanzar Car Audio... • Answered on Mar 16, 2017
How to wire a lanzar 2000 watt sub
Into what?
1/24/2017 9:24:26 PM • Lanzar Car Audio... • Answered on Jan 24, 2017
Series wiring lanzar p124d/
What is a Lanzar P124D?
1/17/2017 7:28:41 PM • Lanzar Car Audio... • Answered on Jan 17, 2017
Please clarify your question on whatever this product is.
1/17/2017 6:57:09 PM • Lanzar Car Audio... • Answered on Jan 17, 2017
Lanzar Optidrive OPTI500.2 Car Audio Amplifier Logo
1 questions posted
Top Lanzar Car Audio & Video Experts
Steve Sweetleaf
Steve Sweetleaf
xxxxxx xxx
ADMIN Andrew
ADMIN Andrew
Are you a Lanzar Car Audio and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Lanzar Car Audio & Video
Most Popular Question
many watts lanzar optidrive 500 2 push
  • Car Audio & Video
