20 Most Recent
RCA ION-ITTUSB05 Turntable Questions & Answers
How to use usb to rca cable - Driver
That cable will not allow you to view your computer on your TV.
If you have S-video, DVI, HDMI or VGA out on your computer AND the corresponding port on your TV, then you should be able to fairly easy. What TV & computer do you have?
How do I remove the
Lift the rubber mat off the platter and notice the two large holes for your fingers to fit into. Simply lift the platter off the base by pulling.
Sounds from turntable
There will be some feedback from the turntable, and this is totally normal. Ive actually heard the music from the needle itself, and is nothing to worry about
Plate leans to one side, dragging base as it turns
Ship it straight back, but get an RMA first if you bought it on-line.
If its from a shop same deal take it back and ask for another (do not accept it being repaired)
I understand that when we get a new toy we want to play. But I would hate to play with a new toy that I knew was repaired from new. That would take a lot of the pleasure out of it.
ION USB turntable working famously
Thanks for contacting Fixya.
iTune version 8.0 is not compatible or understood by Vinyl converter. I would request you to please uninstall it and install an older version so that it starts recognising the Vinyl converter and iTune starts recognising it.
God Bless.
My RCA home theater system,
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
1/15/2024 9:01:27 AM •
RCA Audio...
Answered
on Jan 15, 2024
