20 Most Recent Navigon 7100 GPS Navigator GPS Receiver Questions & Answers
From what I've been reading, Navigon is pulling, or has pulled out of the US. They claim to still support map updates if you purchased a subscription but to spend $ on it now would be risky in my opinion
Navigon 7100 GPS... | Answered on Apr 28, 2014
your battery is gone requires new one.
Navigon 7100 GPS... | Answered on Jul 06, 2013
The battery can be replaced but it will require you to remove the old one and find a matching voltage and sized battery on ebay. you will have to change the connector to the one off the original battery pack.
It has been a while since i have done one of this model but it can be done.
Navigon 7100 GPS... | Answered on Mar 20, 2012
Hello
It is due to a software error. Reset the device and install the latest sofftware update from Navigon website.
Navigon 7100 GPS... | Answered on Jun 22, 2011
Activation cord is in the freshmaps activation card that comes with purchas of device.It is on the back of the card remove plastc with nail and you will get 15 digits number in 3block with 5 digits each.
Navigon 7100 GPS... | Answered on Feb 25, 2011
I had the same problem and this fixed it: Connect the navigon to your computer and go into the files directory and create 3 new empty folders, as follows: (You may want to back up your navigon 1st) After i created these empty folders, I was able to go into settings and turn Stree names on
Create these empty folders within MN6\sound folder.
Celine_67_tts
Isabela_22_tts
Sarah_21_tts
Navigon 7100 GPS... | Answered on Feb 18, 2011
The error code signifies that "You might want to check the hardware documentation for more information about diagnosing the problem"
If you are using a laptop, turn the computer off, remove the battery and put it back in after 30 secs. Turn the laptop on then connect the GPS.
If you are using a desktop, just hold down the power button until the computer shuts down. Turn it on again after 30 secs and connect the GPS.
If this does not work, I suggest to uninstall and reinstall the drivers. If this fails, update your BIOS.
Last thing you can try is to re seat your hard drive and RAM.
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
Navigon 7100 GPS... | Answered on Oct 26, 2010
Hi guimonds,
Make certain you have the unit plugged into external power, and the indicator light (LED) is ON. It would be best if the LED shows "Green", indicating a full charge on the battery also.
Place a blunt-tipped object (larger paperclip or toothpick with sharp end cut off) into the hole at the reset location, which is on the bottom left part of the GPS. Press down for 10-15 seconds on the reset button, then release. Now, press and hold the On/Off/Standby for at least 6 seconds (try 10-15 seconds if needed) to power unit back on. If there is still no power-up, then your unit may be defective. Download the complete 110-page manual from here for more information:
http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man
I hope this helps get it working. If I can help further, please let me know. Thanks.
Regards, Bill
Navigon 7100 GPS... | Answered on Sep 18, 2010
forget it if you dont have the unlock code its useless and may even be hot!
Navigon 7100 GPS... | Answered on Sep 12, 2010
do you still need help with this...as for your window mount, if it has clamp like holder, thats not the original for a 7100...it has to be an after market and all the ones made like that either have a little button on the side,back top or bottom to release it...some you have to push it a few times and it will expand a little at a time.
bill
Navigon 7100 GPS... | Answered on Aug 21, 2010
Navigon 7100 GPS Navigator GPS Receiver Logo
Popular Tags
58 questions posted
Top Navigon GPS Experts
Marvin
Marvin
Anthony Ward
Anthony Ward
Are you a Navigon GPS Expert? Answer questions, earn points and help others
View Most Popular
Navigon GPS
  • Navigon GPS
Most Popular Question
navigon7100 hav nt used couple months
  • GPS
