FixYa.com
1999 Daewoo Lanos
All Products > Daewoo > Cars
Problems with 1999 Daewoo Lanos?
Troubleshooting and Support
Solved Problems for 1999 Daewoo Lanos RSS Feed Post a New Problem
timing belt
timing belt
1 Solution
car struggling and overheating on an...
I travel alot.The car started struggling and became hot on a incline. stopped and allowed to cool, perfectly fine. took...
1 Solution
lanos woes
engine revs excessively after washing
1 Solution
That happens to him?
The injectors do not receive energy to give step to the petrol. For that it(he,she) can be? The car is a daewoo lanos...
1 Solution
Problem with fuel injection
Hi, my 1998 Daewoo Lanos is giving me some problems. When it runs at a slow speed, a little bit under 1500 rpm and...
1 Solution
daewoo lanos 1998
i have the problem when i give the sudden pickup it knok's if i give the slowly it is ok what could be the problem
1 Solution
1999 Daewoo Lanos Air Bag
1999 Daewoo Lanos Air Bag light continously on. I have diconnected battery and checked the conections of the...
1 Solution
View All
Solved Problems for All Daewoo/Lanos
sound like wheele bearing gone
sound like wheele bearing gone but there is no play in any of the wheeles
1 Solution
hi i have a daewoo
hi i have a daewoo lanos 1.6 auto it sounds like a wheele bearing gone but there is no play in the wheeles any idea
1 Solution
Can my 98 1.5L Daewoo
Can my 98 1.5L Daewoo Lanos sohc be made more fuel efficent if so whats the best method?
3 Solutions
i am replacing the timing
i am replacing the timing belt and have moved the crank. I tried to set the notches to where they should be but i still...
1 Solution
how do you check the
how do you check the automatic ytransmission fluid level on daewoo lano 1999 with 1.5litre motor ? also what is ATF...
1 Solution
I HAD A CAR DAEWOO
I HAD A CAR DAEWOO LANOS 2001 AND MY RADIO SAYS COD AND IT DOESNT WORK I TRIED EVERYTHING AND IT DOESNT WORK HELP ME PLZ
1 Solution
brake lights not working
1 Solution
Unsolved Support Problems
Unsolved Problems for 1999 Daewoo Lanos RSS Feed Post a New Problem
mechanics
how to change heater in daewoo lanos1998
Post a Solution
replacement horn
The old hooter has two wires black and green. The new twin horn from a renault clio at the breakers only has one wire....
Post a Solution
replacing a window regulator
Because of the cost, we would like to try and replace a window regulator ourselves. Is it to technical to do on your...
Post a Solution
2000 daewoo lanos
I can't seem to get the engine to start. it turns over just fine but doesn't fire. i already disconnected the fuel line...
Post a Solution
Unsolved Problems for All Daewoo/Lanos
My daewoo makes a air
My daewoo makes a air sound when i put it in gear like its sucking air in somewhere,its a daewoo ciela not a lanos
Post a Solution
When taking off/accellerating the car
When taking off/accellerating the car has no power. We have replaced the fuel filter and throttle postion sensor. The...
Post a Solution
The ABS light is permanently
The ABS light is permanently on, and it diagnosed with the effect from the speed sensors. And don't know what or where...
Post a Solution
Vent selector won't move off
Vent selector won't move off of dash vents, I can manually reach underneath and push it back to the defrost vent, but if...
Post a Solution
problems with transmission
Post a Solution
Change Fuel Filter
Please Can You Help How Do Change a Fuel Filter On A Dawoo Matiz 1999 It Looks as If there are nuts on both ends or do...
Post a Solution
Where is the low pressure
Where is the low pressure port for a 2000 Daewoo Lanos?
Post a Solution
Tips & Tricks
Post a New Tip
Specifications
Key Features
Fuel TypeGasoline
SizeSubcompact
ModelLanos
Year1999
ClassSedan
Engine Size1.6L - 4 Cylinders
Seating Capacity5 Seats
Pricing
Original List Price8,749 - $11,719
Daewoo Contact Information
Main support number800-323-9668
Support FAX973-384-9250
Email supportservice@e-daewoo.com
Sponsored Links
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
