FixYa.com
2002 Daewoo Lanos
All Products > Daewoo > Cars
Problems with 2002 Daewoo Lanos?
Troubleshooting and Support
Solved Problems for 2002 Daewoo Lanos RSS Feed Post a New Problem
daewoo lanos 2002 problem
dave, there is spark in every wire and on each plug. what now? i am not the most technical guy around, but this is...
1 Solution
dave, timing belt is in tact, and tension is fine, ignition systems are dry! i must still check the spark plugs, will...
1 Solution
2002 DAEWOO LANOS PROBLEM
HI GUYS, I HAVE A 2002 DAEWOO LANOS. LAST NIGHT ON MY WAY HOME, IT LOST POWER, I GEARED DOWN AND IT PICKED UP SPEED...
1 Solution
Daewoo Lanos, turns over but will not...
The car turns over but will not fire-up. I have gotten it to fire-up by spraying engine starter fluid down intake duct....
1 Solution
back fire
i have a lanos 2002 it has new plugs ht leads and ignation coil yet when you start the engin the car back fires and the...
1 Solution
help
lanos 1.3 2002 when you start the car the engine miss fires plus are new ht leads are new compresion is good eignation...
1 Solution
reset passcode for radio of 2002 daewoo...
I just bought this 2002 daewoo lanos but radio needs passcode. thank you
1 Solution
View All
Solved Problems for All Daewoo/Lanos
sound like wheele bearing gone
sound like wheele bearing gone but there is no play in any of the wheeles
1 Solution
hi i have a daewoo
hi i have a daewoo lanos 1.6 auto it sounds like a wheele bearing gone but there is no play in the wheeles any idea
1 Solution
Can my 98 1.5L Daewoo
Can my 98 1.5L Daewoo Lanos sohc be made more fuel efficent if so whats the best method?
3 Solutions
i am replacing the timing
i am replacing the timing belt and have moved the crank. I tried to set the notches to where they should be but i still...
1 Solution
how do you check the
how do you check the automatic ytransmission fluid level on daewoo lano 1999 with 1.5litre motor ? also what is ATF...
1 Solution
I HAD A CAR DAEWOO
I HAD A CAR DAEWOO LANOS 2001 AND MY RADIO SAYS COD AND IT DOESNT WORK I TRIED EVERYTHING AND IT DOESNT WORK HELP ME PLZ
1 Solution
brake lights not working
1 Solution
Unsolved Support Problems
Unsolved Problems for 2002 Daewoo Lanos RSS Feed Post a New Problem
diagnostic codes for 200 Daewoo...
Pulled trouble codes with OBD ll scanner. Got one code. P0300. Random/ multiple misfire, cylinder misfire detected. so,...
Post a Solution
New fuel pump.............
Dave, I'm back with more to the story! After all the troubleshooting on original fuel pump, I ended up replacing fuel...
Post a Solution
Cigarette Lighter
Hi, The cigarette lighter in my 2002 Daewoo Lanos isn't working. I had a look at the fuse box to see if it needed...
Post a Solution
DAVE,THANKS, I FOUND THE PROBLEM. THE TIMING BELT WAS IN TACT, I JUST DIDNT SEE THAT A COUPLE OF TEETH BROKE OFF THE...
Post a Solution
iddle stops
sometimes the car just turns off and you start back again with out ploblem.
Post a Solution
daewoo lanos
I have a daewoo lanos that is giving me error codes and i do not have a book to know what the codes means. Do you know...
Post a Solution
UNIVERSAL REMOTE WITH DAEWOO
Lost my remote after a move, bought the universal remote from walmart above and have a 1996 Daewoo. How do I know which...
Post a Solution
View All
Unsolved Problems for All Daewoo/Lanos
1996 Cielo, Car won't start
1996 Cielo, Car won't start on cold mornings, turns over fine but no spark. When it is going it seems to...
Post a Solution
I get a knocking noise
I get a knocking noise that sounds like it comes from the middle/rear underneath of the car. This only happens when I go...
Post a Solution
Daewoo Espero
left C.V joint noisy, how do i remove c.v. for inspection and repair
Post a Solution
My daewoo makes a air
My daewoo makes a air sound when i put it in gear like its sucking air in somewhere,its a daewoo ciela not a lanos
Post a Solution
When taking off/accellerating the car
When taking off/accellerating the car has no power. We have replaced the fuel filter and throttle postion sensor. The...
Post a Solution
The ABS light is permanently
The ABS light is permanently on, and it diagnosed with the effect from the speed sensors. And don't know what or where...
Post a Solution
Vent selector won't move off
Vent selector won't move off of dash vents, I can manually reach underneath and push it back to the defrost vent, but if...
Post a Solution
Tips & Tricks
Post a New Tip
Specifications
Key Features
Fuel TypeGasoline
SizeCompact · Subcompact
ModelLanos
Year2002
ClassSedan
Engine Size1.6L - 4 Cylinders
Seating Capacity5 Seats
Pricing
Original List Price9,199 - $12,999
Daewoo Contact Information
Main support number800-323-9668
Support FAX973-384-9250
Email supportservice@e-daewoo.com
Sponsored Links
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
