FixYa.com
1999 Daewoo Leganza
All Products > Daewoo > Cars
1999 Daewoo Leganza Repair, Maintenance & Service
Troubleshooting and Support
Solved Problems for 1999 Daewoo Leganza RSS Feed Post a New Problem
serpitine belt for 1999 daewoo laganza ...
need a diagram for serointine belt for daewoo leganza 1999
1 Solution
engine managment light stays on
engine managment light stays on constantly aand when starting the car it cuts out after 5/6 times trying it starts. on...
1 Solution
gas tank on a 1999 daewoo laganza
when i unscrew the gas cap there isn't any hiss or air coming out and i have to put a hose down there to open a valve at...
1 Solution
my immobilizer has bouts of
my immobilizer has bouts of not turning off when trying to start engine, this can go on for ages then all of a sudden...
1 Solution
transmission
my laganza doesn't seem to want to shift into 4th and overdrive untill the engine is at normal running temp. Even if its...
1 Solution
How do you reset the immobiliser on a...
My mechanic has asked me for a spare key lock as the car wont start after putting in the new motor. He said its the...
1 Solution
Necesito comprar un motor 2.0 GM Daewoo,...
Hola amigos, gracias por el soporte, necesito las especificaciones para comprar un motor GM Daewoo, 2.0, Doch. Un solo...
1 Solution
View All
Solved Problems for All Daewoo/Leganza
leganza is loosing all water
leganza is loosing all water behind engine. hose - pump - or freeze plug? looks like a hose but i cant see it too well.
1 Solution
I replaced a busted hose(goes
I replaced a busted hose(goes into engine under alternator)in the coolant system in my 2000 leganza 2 weeks ago.Now one...
1 Solution
How do you put back
How do you put back on a serpentine belt on a 2001 Daewoo Leganza?
1 Solution
2001 daewoo sputters at stops
2001 daewoo sputters at stops and low speeds. found oil in 1st sparkplug hole. advice?
1 Solution
front end looseness when on
front end looseness when on rough surface
1 Solution
Lost the key to my
Lost the key to my Daewoo Leganza. What is the best solution?
1 Solution
2001 Leganza bought in 10-2007
2001 Leganza bought in 10-2007 with 122K miles. 2.2liter DOHC engine with 5speed. Sweet car, but always felt the...
1 Solution
Unsolved Support Problems
Unsolved Problems for 1999 Daewoo Leganza RSS Feed Post a New Problem
Daewoo "door open" light...
I have a 1995 Daewoo Cielo 5 door and the 'door open' light stays on in the dash (somretimes flickering) constantly even...
Post a Solution
How to install a drive belt for a 1999...
How to install a drive belt for a 1999 daewoo leganza. Could I have step by step instruction.
Post a Solution
car wont shift into gear
after the car sits for a while you start the car but you cant shift the car into gear
Post a Solution
clutch
When I push in on my clutch it squeals loud?
Post a Solution
flat spot when driving
flat spot when driving,and engine management light on when starting it does go off but comes back on when stationary any...
Post a Solution
heater matrix
how can i fix a heater matrix on a daewoo laganza
Post a Solution
air cond evap core block valve
does the instrument panel and dashboard have to be removed to install the core block valve in a Daewoo Leganza??
Post a Solution
View All
Unsolved Problems for All Daewoo/Leganza
timing chain sets diagram
Post a Solution
Lost keys to the car;
Lost keys to the car; can't open the door; dealer made keys but they don't work; also tried the slim jim for several...
Post a Solution
Marks for timing on a
Marks for timing on a daewoo leganza 99
Post a Solution
My car was running good;
My car was running good; until I changed its timing belt. I put the marker on the Camshaft at 12 o'clock prior taking...
Post a Solution
i need to replace radiator
i need to replace radiator hoses and i dont know the names of them i need to replace a metal ninety that comes off the...
Post a Solution
Cruise control dont work, I
Cruise control dont work, I never used.
Post a Solution
Replacing the timing belt
Post a Solution
Tips & Tricks
Post a New Tip
Specifications
Key Features
Fuel TypeGasoline
ModelLeganza
Year1999
ClassSedan
Engine Size2.2L - 4 Cylinders
Seating Capacity5 Seats
Pricing
Original List Price14,540 - $18,660
Daewoo Contact Information
Main support number800-323-9668
Support FAX973-384-9250
Email supportservice@e-daewoo.com
Sponsored Links
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
