FixYa.com
1993 Saturn SC2
All Products > Saturn
1993 Saturn SC2 Repair, Maintenance & Service
Troubleshooting and Support
Solved Problems for 1993 Saturn SC2 RSS Feed Post a New Problem
Saturn SC2 Hot Start Problem
I have a "new" Saturn. It's a 1999 SC2, same 1.9 Liter engine as the others. Problem is that it start...
3 Solutions
steering wheel
I turned my steering wheel to the left, on my 1994 Saturn SC2, and it made a clicking sound and froze. now the steering...
1 Solution
door panel
ive tried to get the outside door panel off but it stays stuck on even though ive removed all the screws on the inside...
1 Solution
saturn
HOW CAN I TELL IF I HAVE A 1994 SC1 OR SC2
1 Solution
Changing the oil
Where is the oil filter
1 Solution
98' saturn sc2 coupe
i have a knock in the engine. it gets lound when it is reved up car still moves cant figure out what the issue is can...
2 Solutions
Saturn SC 98 valve cover torque...
If there's anyone who has or knows where I could find the diagram to render the correct lbs of torque while tightening...
3 Solutions
View All
Solved Problems for All Saturn/SC2
1999 Saturn SL light green slim/sludge...
I suspect oil is leaking into the water...we've changed the oil a couple times now, and have not been able to detect any...
1 Solution
sunroof motor burnout while open
1 Solution
oil on the bottom of
oil on the bottom of spark plug on two of them. lack power and idle running high.
1 Solution
where is the oil filter
1 Solution
altinator removal
altinator removal
1 Solution
How do you release the
How do you release the ignition tumblers from the casing /
1 Solution
Unsolved Support Problems
Unsolved Problems for 1993 Saturn SC2 RSS Feed Post a New Problem
steering wheel
I turned my steering wheel to the left && it made a clicking sound. now it wont move, turn on, or anything. How...
Post a Solution
fuse panel
need a diagram of the fuse panel to see what fuse belongs to what?
Post a Solution
leaking sunroof in 98 Saturn SC2
From the research we've done, it sounds like it may be the drains, rather than the sunroof seal, that is the problem....
Post a Solution
95 saturn scs
It just would not crank one day and did the day before. it is getting fire and fuel. Computer chip changed and it will...
Post a Solution
97 saturn sc2
Hope someone can help my wifes sc2 starts fine but when you shut it off even after 10 minutes it wont start it cranks...
Post a Solution
Unsolved Problems for All Saturn/SC2
sunroof does not work
Post a Solution
repaced exhaust valves in #3
repaced exhaust valves in #3 and #4 put engine back together all 4 cyl have 170 pressure,but now all4 cyl have oil on...
Post a Solution
where is the oil filter? where
where is the oil filter? where is the airconditioner dryer where is the water temp. sending unit?
Post a Solution
car turn off after staying
car turn off after staying for 10min
Post a Solution
i start the car and
i start the car and it run for about 10mim than it turn off.than i need to wait bout 30mim than it will start again what...
Post a Solution
need a diagram for car
need a diagram for car door mechanism
Post a Solution
Tips & Tricks
Post a New Tip
Specifications
Key Features
Fuel TypeGasoline
Modelsc2
Year1993
ClassSedan
Engine Size1.9L - 4 Cylinders
Seating Capacity4 Seats
Pricing
Original List Price12,795 (Update Date: 16-OCT-03)
Sponsored Links
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
