2003 Lincoln LS
2003 Lincoln LS Repair, Maintenance & Service
Troubleshooting and Support
Solved Problems for 2003 Lincoln LS RSS Feed Post a New Problem
ETC Engine Fail Mode
I was wondering what does ETC engine fail mode actually means and how can I solve this problem.
1 Solution
DATC cools on left side
DATC cools on left side only
3 Solutions
2003 Lincoln LS code P1406
Help! I'm having trouble figuring out what code P1406 means. Something to do with the "Evap system"?
1 Solution
Solved Problems for All Lincoln/LS
when i put a load
when i put a load on the throttle it acts like it doesnt want to go but you let off and then go its fine. and it will go...
1 Solution
left rear window stuck down.
left rear window stuck down. Hear motor working but doesn't lift the window.
1 Solution
driver powerseat wont work 2000
driver powerseat wont work 2000 Lincoln LA
1 Solution
The car is shaking and
The car is shaking and turning off on its on
1 Solution
ac blows a fused
ac blows a fused
1 Solution
install after-market head unit
1 Solution
I have a 2002 Lincoln
I have a 2002 Lincoln LS. My emissions light is on. I have replaced some of the coils and the cabin air filter. I...
1 Solution
Unsolved Support Problems
Unsolved Problems for 2003 Lincoln LS RSS Feed Post a New Problem
Replacing lincoln LS rear brake
Replacing lincoln LS rear brake pads. How do you adjust the electric parking brake so the new pads will fit?
Post a Solution
hard starts
2003 lincoln ls ...i've been having problems starting lately, sometimes i'll have to turn the switch on and off about 3...
Post a Solution
Lincoln LS 2003
I have a Lincoln Ls 2003 and It stalled and said ETC Engine Fail Safe Mode and then I put it on the diagnostics machine...
Post a Solution
Unsolved Problems for All Lincoln/LS
i want to know how
i want to know how to wire my 2005 lincoln ls
Post a Solution
very rough idle, diagnostic reads
very rough idle, diagnostic reads misfire #4 cyl. bank 2 rich ihave tried coils and did not work
Post a Solution
tail lights and tag light
tail lights and tag light not working
Post a Solution
starting my 2001 lincoln ls
starting my 2001 lincoln ls is very touchy. sometimes it starts sometimes it doesn't. when it doesn't the check...
Post a Solution
my check advanced trac light
my check advanced trac light is on(flashing) and car wont start,cranks but wont start this happens about 1 out of 5...
Post a Solution
problem shifting from auto (D5)
problem shifting from auto (D5) into select shift (5th gear)
Post a Solution
overheats when i drive with
overheats when i drive with the air on
Post a Solution
Tips & Tricks
Post a New Tip
WikiManual
Post a New Chapter
Manuals & Guides
Post your Manual or Guide
Recalls
Specifications
Key Features
Fuel TypeGasoline
StyleLuxury
SizeMidsize
ModelLS
Year2003
ClassSedan · Luxury
Engine Size3.0L - 6 Cylinders · 3.9L - 8 Cylinders
Seating Capacity5 Seats
Pricing
Original List Price31,860 - $40,060
Sponsored Links
Loading problems.
Top Experts
Ask Me
guill Guru
6 solutions
Ask Me
shanat Wiz
5 solutions
Ask Me
Richie_as Guru
3 solutions
Repair Service
