FixYa.com
1995 Geo Prizm
All Products > Geo
1995 Geo Prizm Repair, Maintenance & Service
Troubleshooting and Support
Solved Problems for 1995 Geo Prizm RSS Feed Post a New Problem
95 geo prizm hamonic balancer belt pulley
my 95 geo prizm has been eating the belts up,the harmonic balancer belt pulley had alot of in and out movement,i pulled...
2 Solutions
1995 Prizm...Air Conditioning...Only works...
At about 130K miles had no a/c problems. Just recently replaced the timing belt and I don't know if it is conicidental...
1 Solution
starter 1995 prizm
where is the starter
1 Solution
95 geo prizm steering problem
The steering wheel is turned and wheels are straight. When the key is put in the ignition both the key and the steering...
1 Solution
need to get correct order for cylinders
i had someone try and fix my car but i think that when he put the new distributor cap on he may have put the spark plug...
1 Solution
The dreaded check engine light
I finally got one on my 95 Geo Prizm LSI. It's the first one I've ever had on a car and I'm already panicky. Strangely...
9 Solutions
Solved Problems for All Geo/Prizm
i have a 1991 geo
i have a 1991 geo prizm engine type L4,vin engine code 6 single overhead came. I am going to change the plugs and wires...
1 Solution
ok afew days ago my
ok afew days ago my 93 geo prizm started sergeing at an idle and wile driveing then it started dieing as well. so then i...
1 Solution
engine light is on
engine light is on
1 Solution
I need to take off
I need to take off the cross member to get to the oil pan where are all the bolts I need to remove to drop the cross...
1 Solution
Satbelt does not retract, i
Satbelt does not retract, i can still buckle up, but when i unbuckle the seatbelt just stays in place, and...
1 Solution
heater fan speed varies lights dim
heater fan speed varies lights dim slightly then re-brighten battery "idiot" light does not come on...
Post a Solution
94 Prizm -Bad Starter? battery?
Problem: Turn ignition to 'Start' (nothing happens -no sound) several times (up to 10) before car starts...
10 Solutions
Unsolved Support Problems
Unsolved Problems for 1995 Geo Prizm RSS Feed Post a New Problem
radio
bought 95 geo prizm from original owner. Car had been sitting for two years. Radio is locked. Radio code...
Post a Solution
speed ometer
speed ometer stops working, then works, then stops, ect.
Post a Solution
tail light fuse keeps blowing on my 1995...
Replace the fused, checked to see if I might have had a short some place and nothing so far. I replaced the fuse and as...
Post a Solution
headlight problem
We have a 1995 Geo Prizm and recently the low beam headlights on both sides stopped working suddenly while the high...
Post a Solution
wiring a stereo
some1 cut the wiring harness from the wires that are suppose to go to the back of the factory deck and i need the wire...
Post a Solution
Unsolved Problems for All Geo/Prizm
smoke is coming out of
smoke is coming out of ac vents.
Post a Solution
taillight turnsignal doesnt work and
taillight turnsignal doesnt work and turnsignal light on dash blinks fast,also if you put the bulb in the socket on the...
Post a Solution
vehicle runs great but when
vehicle runs great but when you get to about 30 or 35mph the transmission will not shift any higher? new fluid was put...
Post a Solution
I am interested in purchasing
I am interested in purchasing a 1992 Geo Prizm LSI. It has 144,00 miles. I don't know if the timing belt has been...
Post a Solution
Where is the fan motor
Where is the fan motor resistor module located on a 2001 Geo/Prizm?
Post a Solution
Tips & Tricks
Post a New Tip
Specifications
Key Features
Fuel TypeGasoline
SizeCompact
ModelPrizm
Year1995
ClassSedan
Engine Size1.6L - 4 Cylinders
Seating Capacity5 Seats
Pricing
Original List Price11,975 - $12,640
Sponsored Links
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
