20 Most Recent Mitsubishi SELECT WL639U Rear Projection Television Replacement Lamp RPTV Questions & Answers
Open internal fuse or power supply failure
Mitsubishi... | Answered on Jun 30, 2019
I have a Mitsubishi WD73642 model which I'm having a problem with it turning off. When power is turned on the status light flashes green and appears to be powering up. Then u hear sound. Picture comes on light turns sold green then within a minute the El TV will just turn off no other dianososis lights. TV is not located too close to the Wall. Any ideas why?
Mitsubishi... | Answered on Jun 17, 2019
The bulb is out. You can purchase on amazon for around $20.00. It is a very simple fix. Should take about 5-10 minutes
Mitsubishi... | Answered on Jun 16, 2019
Sounds like its overheating.
Are the fans working properly?
Did you buy a quality bulb (or one of the cheap junk bulbs around $20-$30?)
Mitsubishi... | Answered on Jun 14, 2019
The volume button on the remote or the TV is stuck. Try this first, Turn the TV on from the TV (put the remote in a different room) now turn it down from the TV if the volume stays down, the remote up volume is stuck. If it stays loud The main TV board needs to be replaced. If it stays down carefully take the remote apart. check for tiny screws in the batteries compartment if no screws it all clips. Now clean the remote (try not to touch the curcit board).
Mitsubishi... | Answered on Jun 11, 2019
Do you have the model number available? It should be on the back or bottom of the unit. Before adjusting, clean the heads and verify that the tape is running at the proper height past each head. There are three head assemblies to inspect: the rotating video head, the stationary sync head, and the stationary audio head. The sync signal is on the top edge of the tape and the audio signal is on the bottom edge. If the sync head or an adjacent guide pin has come loose, that could cause tracking problems.
Caution: the video heads are very delicate. They're located in the slots at the bottom edge of the rotating drum. Use a foam-tipped swab with straight isopropyl alcohol, and gently wipe the heads in the same direction as the tape goes (do not wipe perpendicular to the tape direction; you could snap the head off if it snags on the swab).
Mitsubishi... | Answered on Jun 04, 2019
No error code 61 listed, only a 66 error code which indicates lamp issues:
66
A) Lamp did not turn on at P-ON sequence... Check CJ4 circuitry
B) No Lamp Inserted............... No Lamp inserted
C) Disconnected cable between ballast and lamp.... HV connection or lead wire to lamp.
D) Lamp-Enable goes to PWB-MAIN but not to Ballast....Lamp Cartridge Failure
for lamp see the following web site: http://www.shopjimmy.com/dlplamps?tv_brands_select=Mitsubishi&tv_models=Mitsubishi+WD-73638
recommend using the manufacture part# as many replacements for Mitsubishi will not work.
Mitsubishi... | Answered on May 09, 2019
Shorted circuit board.
Mitsubishi... | Answered on Apr 10, 2019
Could be you need to set the output volume on your receiver for the soundbar. Most receivers allow volume output for each speaker
Mitsubishi... | Answered on Apr 02, 2019
Mitsubishi SELECT WL639U Rear Projection Television Replacement Lamp RPTV Logo
1 questions posted
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
WL Mitsubishi
  • WL Mitsubishi
Most Popular Question
in need replacement lamp mitsubishi
  • Televison & Video
