1989 Plymouth Reliant
1989 Plymouth Reliant Repair, Maintenance & Service
Troubleshooting and Support
Solved Problems for 1989 Plymouth Reliant RSS Feed Post a New Problem
1989 Reliant K running poorly
My 1989 Plymouth Reliant K . Usually idles rough and has a little dead spot when taking off from a standing stop. Will...
1 Solution
Dodge Caravan Paint Problems
I have a Dodge Caravan and the paint is peeling all over the hood. I have noticed several other Dodge Caravans...
18 Solutions
K Car Stalling
I???ve got a little problem with my 2.5 L 1987 Plymouth Reliant K car. Its acquired an amusing little feature where it...
2 Solutions
Auto trans., 2000 compared to 05
Are the transmissions better in the 05's than in the 2000's? I had one replaced after 70000 it was covered. Now at...
14 Solutions
CC will not admit axel problem
It appears that the Chrysler Corporation will not admit that there is a problem with the trailer axel on at least the...
18 Solutions
Solved Problems for All Plymouth/Reliant
86 Reliant Wagon Idle Problem
OK Chrysler product experts,solve this one! My mother's 1986 Reliant wagon with only 42K original miles has developed...
4 Solutions
84 k-car shimmy
I own an 84 Plymouth Caravell with 100 k. The car has a bad shimmy between 15 + 40 mph. The tires are good no bent...
3 Solutions
PLYMOUTH RELIANT STALLS
I have a 1988 reliant with a 2.2 fuel injected motor. It stalls, sometimes at an idle or sometimes while driving at...
3 Solutions
'84 Plymouth Reliant Problems
I have two problems with the above car. 1) Power steering fluid disappears from a full reservoir about every 4...
3 Solutions
Reliant '86 car probl
TJ TJ Wow, three Reliants, that must be some sort of record! Maybe you can help me with my 83 Reliant which has 124K...
3 Solutions
'85 Reliant . Mitsubishi Alternator Wiring
FOUND IT! There is a 2-wire connector on the Mitsubishi Alternator. Mine only has 1 wire in it..no wonder my problem...
1 Solution
83 Reliant 2.6 Mitsubishi Engine -...
Have had substantial repairs done on my son's 83 Plymouth Reliant Station Wagon - brakes, belts, hoses, calipers,...
4 Solutions
Unsolved Support Problems
Unsolved Problems for 1989 Plymouth Reliant RSS Feed Post a New Problem
troy01969, If this was sent a couple times earlier my mistake. I'm new to this site. Anyways you replied some time ago...
Post a Solution
Unsolved Problems for All Plymouth/Reliant
'86 Plymouth Relient. How
'86 Plymouth Relient. How do I remove the starter?
Post a Solution
Tips & Tricks
Post a New Tip
WikiManual
Post a New Chapter
Manuals & Guides
Post your Manual or Guide
Recalls
Specifications
Key Features
Fuel TypeGasoline
ModelReliant
Year1989
ClassSedan
Engine Size2.2L - 4 Cylinders
Seating Capacity5 Seats
Pricing
Original List Price7,595 (Update Date: 16-OCT-03)
Sponsored Links
Loading problems.
Top Experts
Ask Me
chiquitit Wiz
8 solutions
Ask Me
thereeses Guru
5 solutions
Ask Me
leetamara Guru
10 solutions
Repair Service
