FixYa.com
1995 Dodge Intrepid
All Products > Dodge
1995 Dodge Intrepid Repair, Maintenance & Service
Troubleshooting and Support
Solved Problems for 1995 Dodge Intrepid RSS Feed Post a New Problem
1995 dodge intrepid overheating problem
after changing radiator,waterpump,timingbelt,hoses,rad.cap,and thermostat the car still overheats.what should i look for...
1 Solution
95 intrepid running rough??
I have a 95 dodge intrepid with the 3.3 L. It started running rough and i have replaced the plugs & wires, the coil...
1 Solution
Won't Start
I have a 1995 Intrepid 3.3L V6 that i recently purchased for $300. it ran fine for a day or two, then i went to leave...
1 Solution
95-97 dodge intrepid just shuts down after...
I haven't been driving my car for over a year, because when i drive it for maybe over 20 minutes it just shuts off and...
2 Solutions
I have had my 1995
I have had my 1995 Intrepid for a few yaers. I seem to be having trouble with my turn signles. and fourway flashers....
1 Solution
Dash light problem
I resently installed a aftermarket CD(not the first one Ive done) into a chrysler intrepid. Eversince I did this the...
1 Solution
Instrument cluster stops working when hot
I have a 1995 Dodge Intrepid and when it's warm outside or the car has been running for a while the instrument cluster...
2 Solutions
View All
Solved Problems for All Dodge/Intrepid
2003 Intrepid with intermitting clicking...
Intrepid SXT 2003 has recently started clicking when trying to start vehicle. If car sets for approx. 2 hours then car...
4 Solutions
1994 Intrepid wierd problem....dies...then...
1994 Dodge Intrepid, 3.3 (not flex) Cruising along and the engine dies and the cruise control light comes on. The...
2 Solutions
Brake lights are out. Can't
Brake lights are out. Can't access the brake lights from inside the trunk. Can't locate the brake light...
1 Solution
my dodge intrepid want start
my dodge intrepid want start it making a clicking sound when i try to stat it
1 Solution
i bought a 96 dodge
i bought a 96 dodge intrepid 3.5 v6 car that ran great except it was leaking oil from somewhere on the front bottom left...
1 Solution
I took the car for
I took the car for a 31 mile drive and i got to my exit i turned left and got about 200 to 300 feet off the ramp and the...
1 Solution
transmission solenoid pack
1 Solution
Unsolved Support Problems
Unsolved Problems for 1995 Dodge Intrepid RSS Feed Post a New Problem
engine diagnostic codes
My check engine light gives me 3 codes. 12, 21 & 52. what do these codes mean? It's a 1995 Dodge Ram 2500. codes 12...
Post a Solution
fuse panel 1995 dodge intrepid
I accidentally blew the radio and power door fuses in a battery install. Does anyone have a fuse panel diagram? Thanks
Post a Solution
ovrheats
after 2 motors a flush t-stat timing check/ preasure test no bad heads or intake this car overheats at uneven intervals...
Post a Solution
Brake Lights Not Working
High Stop Light works fine. Turn Signal Lights work fine. Tail Lights work fine. NO BRAKE LIGHTS. I have checked the...
Post a Solution
Unsolved Problems for All Dodge/Intrepid
trans will not change
trans will not change it just stays in second gear scanner says power to mod is gone where will i find it
Post a Solution
electronic malfunction and entire car
electronic malfunction and entire car shuts off
Post a Solution
we are needing to get
we are needing to get a vacuum diagram for a 2001 dodge intrepid.
Post a Solution
I need to install a
I need to install a gooseneck intake
Post a Solution
it stalls and dies all
it stalls and dies all the time and the battery is brand new
Post a Solution
I have a 1998 dodge
I have a 1998 dodge intrepid with codes P0700 & P0750. How bad is this?
Post a Solution
Tips & Tricks
Post a New Tip
Specifications
Key Features
Fuel TypeGasoline
SizeFull-size
ModelIntrepid
Year1995
ClassSedan
Engine Size3.3L - 6 Cylinders
Seating Capacity5 Seats
Pricing
Original List Price17,974 - $20,844
Sponsored Links
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
