20 Most Recent Legacy Audio LA3090D Car Audio Amplifier Questions & Answers
Would need some more info my friend, as when was the last time that it worked.. & what changes have we made on it since it was bought ... post the same to me & in the mean while try these ...
1.) Look for an option DVD menu to turn this safety feature off for ... Go to Setup menu and perform Position
2.) Try checking the connection from your car battery to the audio device...
By the way how old is the player ..
Thanks !!
Legacy Audio Car... | Answered on Mar 28, 2009
Hi Vale Savege, so you may have problems with the connection or the antenna cable
To receive AM, you need to have the connection and antenna cable correctly, while to receive FM, with a shorter cable you can do the same
I sent you the link to download the Service Manual
I hope you can solve the problem
Greetings Franco Dosil
Hola Vale Savege , por lo que comentas puedes tener problema con la conexion o el cable de la antena
Para recibir AM, necesitas tener la conexion y el cable de antena correctamente, mientras que para recibir FM, con un cable mas corto lo puedes hacer igual
Te envio el link para que descargues el Manual de Servicio
Espero puedas resolver el problema
Saludos Franco Dosil
https://usermanual.wiki/Document/XCP410M.742298536/view
Car Audio &... | Answered Yesterday
You need to calibrate put a DVD in on the remote press stop,zoom, up, down screen should pop up touch the cross touch the cross at each corner u will see ok turn off and back on and try it
Car Audio &... | Answered 2 days ago
clocks are in two type one is digital and another is analog it is not specified by you...... sum have a presets inside on board i m not sure it have in your clock show me a picture.
Car Audio &... | Answered 3 days ago
Legacy Audio LA3090D Car Audio Amplifier Logo
Popular Tags
0 questions posted
Top Legacy Audio Car Audio & Video Experts
Dalynn Turner
Mark Skinner
Richard Lukszys
Richard Lukszys
Are you a Legacy Audio Car Audio and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Legacy Audio Car Audio & Video
Most Popular Question
hook up
  • Car Audio & Video
