FixYa.com
2006 Mitsubishi Eclipse
All Products > Mitsubishi > Cars
2006 Mitsubishi Eclipse Repair, Maintenance & Service
Troubleshooting and Support
Solved Problems for 2006 Mitsubishi Eclipse RSS Feed Post a New Problem
1999 mitsubishi eclips, I try
1999 mitsubishi eclips, I try to start and it doesn't start, it won't crank. And I jump start the starter and the...
2 Solutions
idles but will not rev
idles but will not rev up over to 2 grand and back fires thru the air filter, but idles just fine
2 Solutions
2006 Eclipse Lousy Mileage
I'm getting about 17 mpg out of a 4 cylinder Eclipse. Any ideas?
9 Solutions
Solved Problems for All Mitsubishi/Eclipse
CHECK ENGINE LIGHT CAME ON
CHECK ENGINE LIGHT CAME ON WHILE DRIVING, CAR DIED , FOUND OIL IN 3 OF THE PLUGS REPLACED VALVE COVER GASKET AND RINGS...
1 Solution
no voltage to the fuel
no voltage to the fuel pump to prime the system around 9 volts when cracking motor i do have spark
1 Solution
1998 Eclipse - DOOR HANDLES?!
What's up with the damn cheap door handle piece of shit and assemblies? I've had three broken door handles. Two times...
4 Solutions
very bad engine misfire always
very bad engine misfire always get a po300 trouble code..any ideas?
1 Solution
1996 Eclipse Won't Start
Have a 96 Eclipse GS with a 99 engine in it (42K miles on eng). Car was running fine, now will only cranks strong and...
1 Solution
clock goes back to one
clock goes back to one oclock, and keyless entry stopped working, 2007 eclipse
1 Solution
HI,
HI, I WAS WONDERING IF SOMEONE CAN ASSIST ME IN FIXING MY 99 ECLIPSE. I WAS DRIVING ONE DAY AND ALL OF A...
1 Solution
Unsolved Support Problems
Unsolved Problems for 2006 Mitsubishi Eclipse RSS Feed Post a New Problem
Unsolved Problems for All Mitsubishi/Eclipse
I drive a 1998 mitsubishi
I drive a 1998 mitsubishi eclipse gst turbo and it drives fine but when I am stopped at a red light or stuck in traffic...
Post a Solution
can't figure out how to
can't figure out how to remove the alternator from the engine, it is already disconnected, just stuck in the area it...
Post a Solution
Car is overheating and leaking
Car is overheating and leaking antifreeze.
Post a Solution
The battery was disconnected on
The battery was disconnected on my 1998 Mitsubishi Eclipse RS, I have lost the code for the radio.
Post a Solution
As a locksmith, I have
As a locksmith, I have a code for an Eclipse E5855; but, I don't have the "cuts". I have software...
Post a Solution
Tips & Tricks
Post a New Tip
Specifications
Key Features
Fuel TypeGasoline
StylePerformance · Electric/Hybrid
SizeCompact
ModelEclipse
Year2006
ClassCoupe · Hybrid
Engine Size3.8L - 6 Cylinders
Seating Capacity4 Seats
Mitsubishi Contact Information
Main support number800-332-2119
Support FAX(714) 229-3854
Email supportCustomerCare@meus.mea.com
Sponsored Links
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
