20 Most Recent KHypermedia (KDVRW8X) (20730176) DVD+RW Burner Questions & Answers
Helloo
I Dont Think Anyone Gets An Installation Disc With A ROM
Wierd..........
Anyway U Should Just Plug It In (The Drive) And It Should Plug and Play Function. If You Are Running Vista or XP
OtherWise If A box Appears That Cannot Locate Driver Or Insert Installation Disc Like In Vista Just Browse My Computer From There and Put This Address to Search - YOur Win Drive
ex -: C:/Windows
And Search All Drivers Should Get Installed IF This Doesnt Work Just Comment Or If U Dnt Understand Just Comment On This I Have Some More Solutions...................................................................
Good Day.
KHypermedia... | Answered on Feb 18, 2012
if you you are having problems with you dvd rw
Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone. or
you might have to physically unplug the leads for this cd/dvd then plug them back this should activate the found new hardware wizard or
you might have to uninstall then restart your computer then reinstall your DVD/CD then reinstall the driver for this device
if your computer came with a motherboard disk the drivers could be on it
click start control panel administrive tools computer management device manager scroll down cd dvdrom drives if you see a yellow question or exclamation mark? ! or a red x right click you will need to update the driver or
hope this helps you
KHypermedia... | Answered on Aug 26, 2011
Perform an observation of the written descriptions located on the device burner. DVDR +W is indication of capacity to burn DVD R+W only. Usually, the empty disk has to be compartible with the burners specification to commnece downloads.
KHypermedia... | Answered on Jan 29, 2011
make sure that the dvd burner is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
your drivers may have been corrupted or you might have a virus run your antivrus program
you might have to physically unplug the leads for this cd/dvd burner then plug them back in or
you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device
control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or
hope this helps
KHypermedia... | Answered on Dec 10, 2010
you have to see it you if your drive will burn dvds or cds but it should try changing the dvd you are using +r not -r and look at updating the driver it should correct the problem hope this was helpful:)
KHypermedia... | Answered on Nov 16, 2009
go to the manufacturers web site click support, they will have the software but u will need the model number of the burner.
KHypermedia... | Answered on Oct 23, 2009
computer purchaser should have all type softwere cd. if not computer manufacter kept it on any drive look and write it on cd/dvd. llook your modle and serch this softwere in internet todays we get any type of softwere. But this are are diffrent becauseof operating system as xp and vista.supported. ihadevista i remove this and put sp 3 but i surch it supported softwere from net.(nepal)
KHypermedia... | Answered on Oct 09, 2009
Try to re-install the drivers for the drive.
Hope this helps!
KHypermedia... | Answered on Jan 25, 2009
adding
KHypermedia... | Answered on Aug 06, 2008
It could be a problem of the version you are using with Nero 7, try upgrading. It also could be that you are try to burn the DVD RW at a speed it cannot be burned (say 4x), try burning it at 2x.
Hope this works!
KHypermedia... | Answered on Feb 18, 2008
get checked in itunes options or settings whether the ejection of the drive is check marked or not..
KHypermedia... | Answered on Feb 06, 2008
Easiest way is to get a usb external Floppy Disk Drive?
Computers &... | Answered on Jan 13, 2014
Try both a DVD and a CD-R and burn them if they both burn something then the drive does both if it is a combo drive. John
We don't know because we don't know WHERE you are trying to register with the registrar. We are FIXYA dot com and I doubt who you think you are addressing :>)
Computers &... | Answered 3 hours ago
Sure, no problem, but not here at FIXYA dot com! We are NOT who you think we are.
find one you have send an email to, and ask what the e-mail name is ....then go to your e-mail company and write you have forgot the password...have a nice day over there
Computers &... | Answered 6 hours ago
KHypermedia (KDVRW8X) (20730176) DVD+RW Burner Logo
14 questions posted
Popular Products
Top KHypermedia Computers & Internet Experts
Ekse
Alun Cox
Are you a KHypermedia Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • KHypermedia Computers & Internet
Most Popular Question
computer crashed need kids lost disc
  • Computers & Internet
