FixYa.com
2000 Buick LeSabre
All Products > Buick
2000 Buick LeSabre Repair, Maintenance & Service
Troubleshooting and Support
Solved Problems for 2000 Buick LeSabre RSS Feed Post a New Problem
2000 Buick Lesabre steering problem
Has anyone had their 2000 Lesabre "parking lot" power steering problem fixed yet? Our dealer is aware of the...
1 Solution
how to assemble the rear right calipers...
how to assemble the rear right calipers around the pads?
1 Solution
electronic level control
the electronic level control seems to be stuck with the rear of the car up high, is there a way to fix this?
1 Solution
shakes side2side under acceleration at...
2000 LeSabre shakes side to side at 38-48 mph ONLY when gas is applied past very light acceleration. You can't climb a...
2 Solutions
2000 Buick LeSabre Limited
Headlight and Parking Light switch sticks and will not release to off position. I suspect both switches are on one unit....
2 Solutions
Random Cylinder Misfire
I have a 2000 Buick LaSabre that suddenly started not running well.  The Service Engine Soon light often starts...
2 Solutions
1997 Buick LeSabre
The car shuts down while driving with no warning. I have had the car checked out by 2 different mechanics & they...
1 Solution
View All
Solved Problems for All Buick/LeSabre
1995 LeSabre-Heater fan quit.
Greeetings, 1995 Buick LeSabre: manual climate controls. My heater fan ran intermittently for a week, now not at...
4 Solutions
1995 lesabre backfires and quits after...
I have a 1995 buick lesabre with 105,000 mi on it. It was running fine then Yesterday. I went to start it today It was...
9 Solutions
where is the tps located
1 Solution
throttle position sensor
i have had a buick 1988 lesabre for about two weeks then the service engine light came on. i jumped a wire on the aldl...
2 Solutions
My 1995 Buick LeSabre has
My 1995 Buick LeSabre has an elecrical problem. The car may run fine. Then after stopping it for a while and trying to...
1 Solution
The air conditioner pump is
The air conditioner pump is there any easy way to take this off and replace this?
1 Solution
2001 Buick LeSabre - Noticed
2001 Buick LeSabre - Noticed headlights "flickering" and voltage dropping from 14.9 to 12 volts...
1 Solution
Unsolved Support Problems
Unsolved Problems for 2000 Buick LeSabre RSS Feed Post a New Problem
no spark
I have a 2000 lesabre. I have the random cylinder misfire code. I have replaced plugs and wires the problem is still...
Post a Solution
Intermittent electrical problems
Sometimes the car won't start when you turn the key. The radio doesn't work , the keyless entry won't work , the power...
Post a Solution
motor and transmission mounts
We just changed the motor and transmission mounts on my 2000 buick lesabre because it would give a hard kick when put...
Post a Solution
Noise that sound like a dry belt or a...
I have a noise that sounds like a stuck belt or even a air condition whinning. We took the main belt off to see if we...
Post a Solution
Heated drivers seat
Driver's seat doesn't heat. The switch does not act or feel normal.
Post a Solution
2000 Buick LeSabre ingintion coil and...
I need to know where the ignition coil and the module are in my 2000 Buick LeSabre so that I can replace them.
Post a Solution
rear lights,emergency flashers not working
hello there the only l;ights that work on my car are when the headlights are on high beam!! what could be the prob. we...
Post a Solution
View All
Unsolved Problems for All Buick/LeSabre
My tail lights on my
My tail lights on my 1992 buick le sabre dont work.Front running lights are fine & the brake lights and turn...
Post a Solution
Buick LeSabre Limited headlight switch
Buick LeSabre Limited headlight switch stuck in on
Post a Solution
I had to change the
I had to change the motor on my car, and now the new fuel pump that I put on it will not work. I just brought a relay...
Post a Solution
Battery won't hold a charge,
Battery won't hold a charge, and when being jumped starter is not engaging, not even a click , but evry thing else is...
Post a Solution
Car will not start. new
Car will not start. new battery installed.
Post a Solution
how do i fix the
how do i fix the pulley that broke from the water pump
Post a Solution
1997 BUICK LESABRE. DRIVERS SIDE
1997 BUICK LESABRE. DRIVERS SIDE FRONT AND BOTH SIDES REAR FLOORBOARDS ALWAYS WET.
Post a Solution
Tips & Tricks
Post a New Tip
Specifications
Key Features
Fuel TypeGasoline
SizeFull-size
ModelLeSabre
ClassSedan
Engine Size3.8L - 6 Cylinders
Seating Capacity6 Seats
Pricing
Original List Price22,890 - $26,695
Sponsored Links
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
