2008 Mitsubishi Eclipse
2008 Mitsubishi Eclipse Repair, Maintenance & Service
Troubleshooting and Support
Solved Problems for 2008 Mitsubishi Eclipse RSS Feed Post a New Problem
oil leaking out of spark plug
while checking spark plugs the last one on the right I pulled off the wire and the wire was covered about half way up...
1 Solution
Solved Problems for All Mitsubishi/Eclipse
1996 Eclipse Won't Start
Have a 96 Eclipse GS with a 99 engine in it (42K miles on eng). Car was running fine, now will only cranks strong and...
1 Solution
when i start the car,
when i start the car, the engine had started then it died, then everytime i go to start it the engine will just turn...
1 Solution
my rpms go to high
my rpms go to high and doesn't have the same power
1 Solution
automatic transmission shifts hard and
automatic transmission shifts hard and down shifts hard from 1st to 2nd 3rd to 2nd
1 Solution
1994 mitsubishi outo transmission slips
1994 mitsubishi outo transmission slips when cold
1 Solution
Problem # 1: My
Problem # 1: My car's steeering wheel is locking up when I turn a corner. I notice it when I'm making right hand...
1 Solution
can you use a timing
can you use a timing light to check time
1 Solution
Unsolved Support Problems
Unsolved Problems for 2008 Mitsubishi Eclipse RSS Feed Post a New Problem
Car Fuel door
I purchase a 2008 Mitsubishi Spyder Eclipse last September and the Fuel door got stolen.  I purchased a new one...
Post a Solution
Unsolved Problems for All Mitsubishi/Eclipse
spark plug tube seal repair
Post a Solution
I have a 1990 Mitsubishi
I have a 1990 Mitsubishi Eclipse and have replaced the ECU 3 times with used units. The 3rd and current replacement is...
Post a Solution
the car only fires on
the car only fires on two cylenders.
Post a Solution
lights pulsing, not tied into
lights pulsing, not tied into RPM of motor.
Post a Solution
i just replaced my rotors
i just replaced my rotors on my 96 eclipse and when i finished and went to move it its like its stuck the wheels dont...
Post a Solution
2005 Eclipse GTS purchased used
2005 Eclipse GTS purchased used in March 08. Replaced battery in July. With new battery, lights still flickered...
Post a Solution
takes off sluggish, smooths out
takes off sluggish, smooths out when you get going
Post a Solution
Tips & Tricks
Post a New Tip
WikiManual
Post a New Chapter
Manuals & Guides
Post your Manual or Guide
Specifications
Key Features
ModelEclipse
Year2008
Mitsubishi Contact Information
Main support number800-332-2119
Support FAX(714) 229-3854
Email supportCustomerCare@meus.mea.com
Sponsored Links
Loading problems.
Top Experts
Ask Me
RapidTran Guru
4 solutions
Ask Me
rgall85 Guru
18 solutions
Ask Me
donny12 Wiz
4 solutions
Repair Service
