convection cooking how to set oven control for convection baking for GE profile duel fuel. ...
(More)
convection cooking how to set oven control for convection baking for GE profile duel fuel. Misplaced my manual. Thank you, JW
I have a GE Spector gas oven. I cleaned the oven and now it is stuck in clean mode. When try to set...
(More)
I have a GE Spector gas oven. I cleaned the oven and now it is stuck in clean mode. When try to set temp, it says clean...help!
GE self cleaning electric range clock, oven light and oven on light all work but oven or surface...
(More)
GE self cleaning electric range clock, oven light and oven on light all work but oven or surface units won't heat up at all. Any recommendations would be greatly appreciated
My front right small/large burner turns on and off but when on it will always be on high no matter...
(More)
My front right small/large burner turns on and off but when on it will always be on high no matter where the knob is set.
Had similar problem in past where control lockout was somehow activated. The solution then was to...
(More)
Had similar problem in past where control lockout was somehow activated. The solution then was to turn power off at Breaker (or unplug) and system reset. This time there was a power outage and perhaps a surge when power was restored. Initially all systems worked and about 1-2 hours after I had reset the clock all panel lights went out. I have tried turning breaker off and back on several times and I know all four burners work. There seems to be no power to the control panel. I can probably fix it myself if someone can identify the part(s) needed. Thanks
This advice is for GAS ovens with glow bar type
igniters. This is a fairly simple repair
that MOST do-it-yourselfers can accomplish with just a...
written by jsrock516
This advice is for Electric Ranges equipped with glass smooth tops. If it becomes necessary to replace the cook top due to wear or damage, here's some...
Here is a useful tip in identifying a frequently reported problem on some model ranges and wall ovens equipped with an Electronic Range Control (ERC)...
This "high end...?' range blew up twice early on when using the oven. My wife had her hair and eyebrows burned just by opening the oven door to...
written by skywagon185
As oven probes age, they can sometimes generate error codes on kitchen ranges and render them inoperative. The error code varies between models, but...
This advice is on how to replace a bad element on kitchen ranges that utilize ELECTRIC heating elements for baking and broiling. 1. UNPLUG the range...
Honest, Dependable, Available & Professional!
Appliance Parts Supply! We Ship Nationwide. Our Phones Answered From 7 AM - 9 PM CST Mon - Sat.
Over 30 Years Experience!
972-859-0929 - Call us NOW!
www.accurate-appliance-service.com
