20 Most Recent
Dynex 802.11g Wireless-G Laptop Card Questions & Answers
I have a Dynex 802.11 Wireless G laptop Card. I
openuse.org may help you.
It may be your Lan settings not configured.To check this go to tools in int explorer and click on connections/LAN/SETTINGS.Make sure the box,"Automatically detect settings,"is ticked.
I use the 802.11g enhanced wireless g notebook
For that you need to enable DHCP in router.
Connect your router to computer with ethernet cable then you can access it with following default link.
http://192.168.15.1
or
http://192.168.2.1
If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it.
Then it ask for user name and password.
Type user as "admin" and password as "admin" or "password" or blank.
Then you can see configuration page of router.
Click on DHCP and enable then save settings and restart router then enable ip address get automatic in network adapter property.
Let me know if you need further assistance.
Thanks for using FixYa.
Hello, I just installed the
I am not sure, but you may have to set up the browser to use the internet card to use it for internet.
Good Luck!
Where do I insert the Dynex card?
You insert the
dynex pcmcia network card in a pcmcia slot, if your laptop has one.
If you don't find a place you can insert insert the card, that means that probably your laptopt does not have a pcmcia slot; maybe it gas a exopress card slot, smaller and more frequent in recent laptops.
Dynex Router problem
try to reset your wireless router...look for the reset button and press it with a small pin for at least 10 sec. see if it will recognize the router after reseting...
DNS error when trying to connect to internet
1- Try setting your own DNS server settings, right click on your network connection > properties > TCPIP v4 > edit DNS settings ( use dyndns.com as a dns for example).
2- Try refreshing your DNS cache:
start > run > cmd > and type: ipconfig /flushdns
Hope it helps !
Need driver for dynes
The drivers can be found here
http://www.dynexproducts.com/pc-593-4-dynex-80211g-wireless-g-laptop-card.aspx
CONNECTION
it means that the card is still inactive, it could be from the card itself or your setup
Dynex 1.3mp driver update for windows 7
Unfortunately, Dynex no longer provides driver updates for their 1.3MP webcam on Windows 7 as the product has reached its end of life and is no longer supported. However, you may still be able to use the webcam with the existing drivers that came with it or with the generic drivers that are built into Windows 7.
To check if your webcam is recognized by Windows 7, follow these steps:
- Plug in your Dynex 1.3MP webcam to your computer's USB port.
- Click on the "Start" menu and select "Control Panel".
- Click on "Hardware and Sound" and then select "Device Manager".
- Look for the Dynex webcam under the "Imaging devices" or "Cameras" category. If it is listed, then your webcam is recognized by Windows 7.
If your webcam is not recognized by Windows 7 or is not functioning properly, you may want to try downloading and installing a third-party driver update software like Driver Booster or Driver Easy. These programs scan your computer for outdated or missing drivers and automatically download and install the latest versions for you.
Alternatively, you can try searching for a compatible driver on third-party driver download sites, but be cautious as some of these sites may contain malicious software. It is always recommended to download drivers from the manufacturer's website or from trusted sources.
