20 Most Recent Insignia Sport MP3 Player Questions & Answers
we can not help try the manufacturer's website
Insignia Sport... | Answered on Feb 13, 2018
Unfortunately You Tube doesn't have a way of putting videos onto another player. It's only designed to play back on portable phones like Blackberrys, Iphones, and G1s. Can playback on series 3 Tivos as well.
Insignia Sport... | Answered on Mar 18, 2016
pls my scream is broken how do i change it?
Insignia Sport... | Answered on Sep 12, 2014
I had the same problem. The reason is because you have not charged your player, in a while.
First of all, try this.
Reset the Insignia Pilot if it freezes during normal use. To reset the device, press and hold the "Power/Hold" switch to the right for approximately 10 seconds until the screen turns off. The "Power/Hold" switch is located on the top of the player.
If that does not work, you need to remove the battery and then put it back.
Here's how to do it.
https://www.youtube.com/watch?v=29ULLzZqHLI
Then plug your cable and wait until it comes back to life. Be patient, it may even take a couple of days, until a full charge is accomplished.
Insignia Sport... | Answered on Jun 28, 2014
MP3 is a format recognized by all computers.
What type of player you have? You may need a specific way to connect or specialized software to transfer song from the player onto your computer.
need new spaeker or claen urs
rate this post
Insignia Sport... | Answered on Oct 14, 2012
If your subscribtion to rapsody (or best buy, whatever they call it) digital music store ran out it will do that to any song you got from the store until you renew your subscription. Try putting a song on there that you own (you didn't download from rapsody) and it should play. I wouldn't bother renewing the subscription though, the store has a poor library (I couldnt' even find don't worry, be happy). Just download your songs from limewire
Insignia Sport... | Answered on Dec 14, 2011
file system fail format file system
Insignia Sport... | Answered on Sep 12, 2011
If you are inclined to be adventurous I would try opening it up and check if the battery still has any voltage on it with a multimeter. (Shere is a little shield shaped sticker on the back that covers a screw for the battery cover). Since the battery died on mine about a year ago I have been running my Sport from a set of 4 AAA NiMH rechargeable cells. The fact that it does not respond to the PC suggests that the USB connector may have gotten damaged so it is not making a proper connection to charge the battery anymore. If you have this problem you are probably out of luck, unless you are good with a soldering iron and can replace the connector on the PCB - It is a very common type. But check with another USB cable first, (like I said, a very common type) AND make sure there is no damage to the connectors at the PC end.
Insignia Sport... | Answered on Aug 22, 2011
refurbish to manufactier settings should be fine if not sell if before it goes bad
I believe your mp3 player is Insignia..... If yes, carefully follow the instructions below;
  1. Connect your Insignia player to a USB port on your computer using the USB cable.
  2. Download, install and run Rhapsody if you do not already have the software, click here; http://www.rhapsody.com/-software
  3. Click "File," then "New Playlist" to create a playlist in Rhapsody.
  4. Create a name for the playlist.
  5. Drag songs from your music library called "My Library" to the playlist you just created. You have to drag the songs onto the playlist name for them to appear.
  6. Sync the playlist from Rhapsody to your Insignia player. Go to "Tools," "Preferences" and then "Devices." Find your Insignia player and click "OK." A sync window will appear.
  7. Click "OK" to sync your playlist to the Insignia player.
I hope you find the above helpful.
Good luck.
Insignia Sport... | Answered on Apr 23, 2011
Insignia Sport MP3 Player Logo
172 questions posted
Top Insignia Audio Players & Recorders Experts
Alan Matzke
Alan Matzke
Steve Allison
Steve Allison
Are you an Insignia Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Insignia Audio Players & Recorders
Most Popular Question
insignia sport will not turn off
  • Audio Players & Recorders
