GE 5.8 Cu. Ft. 2-Cycle Extra-Large Capacity Electric Dryer - White-on-White
Problems with GE 5.8 Cu. Ft. 2-Cycle Extra-Large Capacity...?
Ask our Experts
Chat with a Pro
Tell us why
Share your Experience
Do you recommend the
GE 5.8 Cu. Ft. 2-Cycle Extra-Large...
Problems
& Solutions
Manuals
& Guides
Repair
Service
Reviews
& Ratings
Warranty
& Spec
Troubleshooting and Support
Solved Problems for GE 5.8 Cu. Ft. 2-Cycle Extra-Large Capacity Electric Dryer - White-on-White RSS Feed
View More Results for GE 5.8 Cu. Ft. 2-Cycle Extra-Large Capacity Electric Dryer - White-on-White
Find a Manual
GE 5.8 Cu. Ft. 2-Cycle Extra-Large Capacity Electric Dryer - White-on-White Manuals & Guides
Sorry. We do not have a manual for this product.
You can...
  • Search for manuals of related products.
  • Ask an Expert to find it!
Tips & Tricks
(Post a New Tip)
Dryer Heating Problems
I have been getting a lot of problems with dryers not heating right. A lot of sloution have been that people have been cleaning out their heat vents... written by rjhahn
Dryer Runs, but Does not Heat
This advice is for all ELECTRIC Dryers that have a "No Heat" problem. Symptom: Dryer turns on, drum spins, but you have no heat. Any of the... written by jsrock516
How to Install a Dryer Belt on Kenmore Elite and Whirlpool Duet Dryers
This advice is for dryer belt replacement on most Kenmore Elite and Whirlpool Duet model dryers. If in doubt, please provide me with a complete model... written by jsrock516
How to change your dryer from 3 wire to a 4 wire power cord. (short and...
Dryers come with a wire or metal strap connecting the center "neutral" terminal to the frame of the dryer. When using a four wire power... written by MNTECH
Washer and Dryer Repair manuals and Parts
Please rate a Fix Ya!!! Thanks jj505 For all Washers/Dryers/Parts http://laundry.manualsonline.com/ written by jj505
Possiable Manuel HELP OR ORDER PARTS LINK
Please rate a Fix Ya!!n Thanks jj505 http://www.repairclinic.com/Home.aspx written by jj505
SAVING TIME & MONEY $$$
To reduce the suction draft and drying time your drier and save some cash, remove the lint catcher and take it to the sink. Run water into it, if... written by DRRXR
Dryer operates but will not heat.
1. Disconnect electrical power to dryer. 2. Remove the lid. 3.On the front panel there is a circuit board (moisture sensor control board) with a six... written by gregorymholt
WikiManual
(Post a New Chapter)
How to Clean a Clothes Dryer Vent
If your dryer vent hasn't been cleaned in the past year or two, it probably needs it. There may even be a bird's nest in there. How do you clean... by wikihow
How to Wire an Electric Dryer
Modern appliances come with separate ground and neutral wires. Generally, this setup is safer, because the current-carrying neutral is not connected... by wikihow
How to Improve the Lifespan of your Clothes Dryer
Most of the problems in a dryer are caused by poor air circulation inside of the dryer. The dryer will suck air from the outside, pass it through the... by wikihow
How to Repair Loose Baffles in Your Dryer Tumbler
Do you hear clanking noises coming from inside of your dryer tumbler? It may be time to replace the dryer baffles. Here is how to check and go about... by wikihow
How to Prevent the Dryer Cord and Terminal Block from Burning Out
Tips on how to prevent the dryer cord and terminal block from burning out. Steps 1. The cause of the dryer cord wires and the terminal block for... by wikihow
Upload Manuals
I need help with
near zipcode:
Please enter your zipcode
Search
Click here to get instant support from our best Experts!
Top Repair Providers for 5.8 Cu. Ft. 2-Cycle Extra-Large Capacity Electric Dryer - White-on-White
Nationwide | 877-477-7278 | Website
Washer and Dryer parts delivered overnight nat... Read More
Featured Listing
Nationwide | 8003571234 | Website
Welcome to Action Appliance Repair. We have bee... Read More
Featured Listing
Nationwide | 7606873360 | Website
Washer and Dryer repair specialists. Why hire som... Read More
Nationwide | 312-404-7574 | Website
Our focus will always be to provide top-notch qua... Read More
Rate and Review the GE 5.8 Cu. Ft. 2-Cycle Extra-Large Capacity Electric Dryer -...
Write a review:
Rate this product:
Would you recommend the 5.8 Cu. Ft. 2-Cycle Extra-Large Capacity Electric Dryer - White-on-White to your friends and family?
Is it reliable?
Is it easy to use?
Is it a good value?
Find a Warranty
Specifications for GE 5.8 Cu. Ft. 2-Cycle Extra-Large Capacity Electric Dryer - White-on-White
Key Features
Warranty Terms - Parts
1 year limited
Warranty Terms - Labor
1 year limited
Product Weight
100 lbs.
Color Category
White
Special Order
No
ENERGY STAR Qualified
No
Moisture Sensor
No
Drum and Interior Finish
Polymer
Control Location
Rear panel
Delayed Start
No
Extra-Delicate Cycle
No
End-of-Cycle Signal
No
Product Depth
26-2/5"
Reversible Door Hinge
Yes
Product Width
27"
Product Height
41-4/5"
Power Source Ratings
240V; 60Hz; 24 amps or 208V; 60Hz; 22 amps
Model Number
DVLR223EGW
Depth with Door Open (in.)
49-1/4
Capacity (cu. ft.)
5.8
Power Source
Electric
Stackable
No
Control Type
Analog
Interior Light
No
GE Contact Information
Main support number1-800-626-2005
Describe your problem:
Top Dryers Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
