20 Most Recent Yamaha Full-Size Keyboard Questions & Answers
Do a factory reset. First try pressing the + and - buttons simultaneously.
Look in your user manual for a complete factory reset and do that.
Yamaha Full-Size... | Answered on Feb 07, 2019
If you know how to use a multimeter then I suggest you measure the voltage from your wall adapter plug that you plug into the keyboard. If that has approx. 9Vdc, then take a look at d151 on the power supply board. See if it is passing voltage. Voltage should pass only 1 way. If you have voltage on one side but not the other then the diode it is open and needs replaced. You can find the diode designator on the board next to the diode.
Yamaha Full-Size... | Answered on Apr 05, 2013
hi there headphone jacks usually only come in 2 sizes, an obviously large one or a small one, (the headphone and the microphone jacks on your computer will be the small ones) if you have a favorite set of phones with a small jack and you need the large one you can buy an adapter that fits the large jack when you plug the small one in. good luck
Yamaha Full-Size... | Answered on Aug 21, 2009
I had similar problem out of the box; fixed by setting Function to Style Volume and adjusting upward.
Yamaha Full-Size... | Answered on May 13, 2009
Becketts Music Ltd Apr 26, 2019
If this is a physical banging noise (metal on plastic or plastic on plastic) it is highly likely the felt damper strips have come away from the frame. Talk to your supplying dealer if under 6 months old it is under warranty.
Yamaha Music | Answered on May 14, 2019
Does it ever turn off?
The PSRE313 uses a rubber on/off switch with a carbon dot on the underside that does wear out. If all is working well I would suggest replacing this rubber switch part number WD893400
Yamaha Music | Answered on Apr 23, 2019
maybe this will help ...... I have a Korg M1 ..... it has a small button battery for maintaining memory and sounds .... mine lasted about 10 years ...... I looked up in Google how to change the battery .... I looked up in my M1 instructions how to reload the sounds .... I had lost all my synth sounds except the basic piano ...... I changed the battery and reloaded the sounds from a backup card I had bought years ago .... M1 works perfectly now .... you probably lost any saved songs .... contact Yamaha how to change the battery and reload the original songs .... any saved songs are gone .... next time, back them up ... good luck
Yamaha Music | Answered on Apr 17, 2019
Yes, an aux jack is looking for a powered input. An electric guitar is just a passive input, like a microphone.
If you're interested, a solution and a great upgrade would be to get a wireless guitar input (battery powered). The wireless receiver would likely have an RCA output that would work with your receiver. Solves your preamp problem and you have a wireless guitar.
Yamaha Music | Answered on Mar 31, 2019
We live in the 21st century, just google it.
Yamaha Music | Answered on Mar 15, 2019
check this out - a pdf schematic manual for P200
http://www.gamato.ws/ja/yamaha/P200/yamaha_p-200.pdf
Yamaha Music | Answered on Mar 12, 2019
Try a master reset to start with.
Turn keyboard off
Turn on whilst holding down highest note on keyboard
Once screen display has complete release key
This will reset to factory settings.
If this doesn't work report back and we can maybe try other solutions.
Dan
Becketts Music Ltd
Yamaha Music | Answered on Mar 11, 2019
This might sound obvious but first of all I would try an older smaller flashdrive. Some large versions are not supported by certain keyboard. Try a simple midi file or similar with a smaller drive, if that works then it could either a procedural error in the way you are completing the task or that the larger drive is not supported.
Did the drive in question previously work?
What size drive are you using?
What are you trying to do? Save work, update software?
Good luck
Becketts Music Ltd
Yamaha Full-Size Keyboard Logo
Popular Tags
7 questions posted
Top Yamaha Music Experts
Michial Gueffroy
Mike
Are you a Yamaha Music Expert? Answer questions, earn points and help others
View Most Popular
Yamaha Music
  • Yamaha Music
Most Popular Question
auto accompament failure yamaha dgx220
  • Music
