Whirlpool 6.5 Cu. Ft. 5-Cycle Super Capacity Gas Dryer - White
Problems with Whirlpool 6.5 Cu. Ft. 5-Cycle Super Capacity Gas...?
Ask our Experts
Chat with a Pro
Tell us why
Share your Experience
Do you recommend the
Whirlpool 6.5 Cu. Ft. 5-Cycle Super...
Problems
& Solutions
Manuals
& Guides
Repair
Service
Reviews
& Ratings
Warranty
& Spec
Troubleshooting and Support
Solved Problems for Whirlpool 6.5 Cu. Ft. 5-Cycle Super Capacity Gas Dryer - White RSS Feed
View More Results for Whirlpool 6.5 Cu. Ft. 5-Cycle Super Capacity Gas Dryer - White
Questions and Unsolved Support Problems
Unsolved Problems for Whirlpool 6.5 Cu. Ft. 5-Cycle Super Capacity Gas Dryer - White RSS Feed
Answer
My Whirlpool dryer is heating up, lint trap and ductwork leading out is clean. However, I can run... (More)
Answer
It just stopped starting. The start button does not kick the dryer on? Is there anything I can check... (More)
Find a Manual
Whirlpool 6.5 Cu. Ft. 5-Cycle Super Capacity Gas Dryer - White Manuals & Guides
Sorry. We do not have a manual for this product.
You can...
  • Search for manuals of related products.
  • Ask an Expert to find it!
Tips & Tricks
(Post a New Tip)
Dryer Takes Too Long to Dry
This advice is for problems with a dryer that runs and heats, but takes entirely too long to dry. MOST dryer heat related problems are due to poor... written by jsrock516
Dryer Runs, but Does not Heat
This advice is for all ELECTRIC Dryers that have a "No Heat" problem. Symptom: Dryer turns on, drum spins, but you have no heat. Any of the... written by jsrock516
How to Install a Dryer Belt on Kenmore Elite and Whirlpool Duet Dryers
This advice is for dryer belt replacement on most Kenmore Elite and Whirlpool Duet model dryers. If in doubt, please provide me with a complete model... written by jsrock516
Installing a 220 VAC Appliance Cord
This advice is on how to correctly install an ELECTRIC DRYER or ELECTRIC RANGE 220-240VAC power cord (US Standards). 3-Prong or 4-Prong ? The... written by jsrock516
Dryer Ducting Installation Advice
Here?s some useful guidance for installing dryer ducting. Improperly installed ducting can cause the following: GAS DRYERS ? Rapid burn cycling and... written by jsrock516
Thorough Dryer Advice
This advice is general in nature, but should assist you in isolating MOST dryer malfunctions. Normally when a dryer starts to exhibit longer dry... written by jsrock516
Dryer Taking too Long to Dry Your Clothes?
A very common issue we deal with on FixYa is clothes dryers that are taking too long to dry clothes. Here's a few tips on keeping your drying time to... written by smartr10U
Dryer Heating Problems
I have been getting a lot of problems with dryers not heating right. A lot of sloution have been that people have been cleaning out their heat vents... written by rjhahn
WikiManual
(Post a New Chapter)
How to Clean a Clothes Dryer Vent
If your dryer vent hasn't been cleaned in the past year or two, it probably needs it. There may even be a bird's nest in there. How do you clean... by wikihow
How to Wire an Electric Dryer
Modern appliances come with separate ground and neutral wires. Generally, this setup is safer, because the current-carrying neutral is not connected... by wikihow
How to Improve the Lifespan of your Clothes Dryer
Most of the problems in a dryer are caused by poor air circulation inside of the dryer. The dryer will suck air from the outside, pass it through the... by wikihow
How to Repair Loose Baffles in Your Dryer Tumbler
Do you hear clanking noises coming from inside of your dryer tumbler? It may be time to replace the dryer baffles. Here is how to check and go about... by wikihow
How to Prevent the Dryer Cord and Terminal Block from Burning Out
Tips on how to prevent the dryer cord and terminal block from burning out. Steps 1. The cause of the dryer cord wires and the terminal block for... by wikihow
Upload Manuals
I need help with
near zipcode:
Please enter your zipcode
Search
Click here to get instant support from our best Experts!
Top Repair Providers for 6.5 Cu. Ft. 5-Cycle Super Capacity Gas Dryer - White
Nationwide | 877-477-7278 | Website
Washer and Dryer parts delivered overnight nat... Read More
Featured Listing
Nationwide | 8003571234 | Website
Welcome to Action Appliance Repair. We have bee... Read More
Featured Listing
Nationwide | 7606873360 | Website
Washer and Dryer repair specialists. Why hire som... Read More
Nationwide | 312-404-7574 | Website
Our focus will always be to provide top-notch qua... Read More
Rate and Review the Whirlpool 6.5 Cu. Ft. 5-Cycle Super Capacity Gas Dryer - White
Write a review:
Rate this product:
Would you recommend the 6.5 Cu. Ft. 5-Cycle Super Capacity Gas Dryer - White to your friends and family?
Is it reliable?
Is it easy to use?
Is it a good value?
Find a Warranty
Specifications for Whirlpool 6.5 Cu. Ft. 5-Cycle Super Capacity Gas Dryer - White
Key Features
Warranty Terms - Parts
1 year limited
Warranty Terms - Labor
1 year limited
Product Weight
124.5 lbs.
Color Category
White
Special Order
No
ENERGY STAR Qualified
No
Moisture Sensor
No
Drum and Interior Finish
Polymer
Control Location
Rear panel
Delayed Start
No
Extra-Delicate Cycle
No
End-of-Cycle Signal
No
Product Depth
28-3/16"
Reversible Door Hinge
No
Product Width
29"
Product Height
43"
Power Source Ratings
120V, 60Hz, 20 amps
Model Number
WGD5300SQ
Depth with Door Open (in.)
50-9/16
Capacity (cu. ft.)
6.5
Power Source
Gas
Stackable
No
Control Type
Analog
Interior Light
Yes
Whirlpool Contact Information
Main support number1-800-253-1301
Describe your problem:
Top Dryers Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
