20 Most Recent Electrolux 30" Self-Cleaning Slide-In Double Oven Electric Convection Range - White Questions & Answers
It's ridiculous why would you want to remove the racks in self cleaning mode you want to clean the racks also what good is self cleaning
Electrolux 30"... | Answered on May 08, 2019
sure call for a repairman as it is under warranty and if you mess with it , you will possibly have none .
Electrolux 30"... | Answered on Jan 16, 2019
Good Morning Kenneth Kozoway, thank you for your inquiry!
I see that you have explained the stove top on your Electrolux range is not responding to touch and the oven controls are working properly. From what you have described it sounds like a possible issue with your control panel or sensor. I would suggest performing a reset on your range and you can do that by disconnecting the power from it for ten minutes. If that does not help correct the issue I would recommend having a professional technician come and perform a proper diagnosis for repair. Hope this is helpful. -Matt
Electrolux 30"... | Answered on Dec 27, 2014
My oven does that when the self-clean button has been pressed. Try pushing any sort of power-off buttons or pushing any buttons that are lit up in attempt to turn them off. Older ovens have a lever you have to slide to lock and unlock the oven door.
Electrolux 30"... | Answered on Sep 15, 2014
If you replaced the entire lock assembly and it still does not work, the control board was originally at fault.
I assume there is no latching action when you call for self clean?
Double check you installation before you go buy a new control board.
Also check wire harness connection from new latch assembly to oven control board.
Electrolux 30"... | Answered on Oct 24, 2013
either you have a blown internal fuse or an element wire shorted on inside back of unit
Electrolux 30"... | Answered on Sep 19, 2011
Electrolux 30" Self-Cleaning Slide-In Double Oven Electric Convection Range - White Logo
44 questions posted
Top Electrolux Kitchen Ranges Experts
Craig Butler
Craig Butler
Archie Ferrarini
Archie Ferrarini
Marvin
Marvin
Are you an Electrolux Kitchen Range Expert? Answer questions, earn points and help others
View Most Popular
  • Electrolux Kitchen Ranges
Most Popular Question
electrolux slide in range model
  • Kitchen Ranges
