20 Most Recent Mad Dog Multimedia Predator 5.1 DSP 6 Channel Sound Sound Card Questions & Answers
theres no drivers available for vista. Windows XP and below only
visit details here:
http://tech.yahoo.com/ps/mad-dog-multimedia-mad-dog-predator-5-1-dsp/1991618858
visit the drivers here:
http://driverscollection.com/?H=PREDATOR%205.1&By=Mad%20Dog&SS=Windows%20XP
Mad Dog... | Answered on Sep 25, 2015
How to set up sound card Mad Dog Multimedia Predator on my win 8
Mad Dog... | Answered on Jan 05, 2013
Dear Fregg,
please download the driver for you sound card , from this site:
http://www.soundcard-drivers.com/companies/1591.htm
Be Happy Always
Regards
Mad Dog... | Answered on Dec 10, 2008
Hey Sue, first thing you need to do is press delete when you first switch the pc on to get into the bios, and under usually intergrated deviced, disable the old onboard sound, and save the settings, load windows normally go into control panel, system, device manager, double click on any sound related devices that has a yellow tag next to it, and click on update drivers, make sure you have the cd in the drive, and let it search the cd for the drivers, do it for each device with yellow tag and then it should work. All the best John
Mad Dog... | Answered on Jan 07, 2008
It is broken. Either replace it,
or purchase an external CD/DVD reader/writer, with a USB interface.
Mad Dog... | Answered on Apr 23, 2015
The model number will be on a tag on the driver. You can also see it under storage devices in menu once installed..
Mad Dog... | Answered on Oct 11, 2012
Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone. or
you might have to physically unplug the leads for this cd/dvd then plug them back this should activate the found new hardware wizard or
you might have to uninstall then restart your computer then reinstall your DVD/CD then reinstall the driver for this device
if your computer came with a motherboard disk the drivers could be on it
click start control panel administrive tools computer management device manager scroll down cd dvdrom drives if you see a yellow question or exclamation mark? ! or a red x right click you will need to update the driver or
hope this helps you
Mad Dog... | Answered on Sep 06, 2011
make sure that the dvd burner is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or the drivers may have been corrupted or you might have a virus run your antivrus program you might have to physically unplug the leads for this cd/dvd burner then plug them back in this should activate the found new hardware wizard or you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps
Mad Dog... | Answered on Mar 25, 2011
use ids...
to burn ur cd n dvd.....
much beer software.....
link ---- http://www.brothersoft.com/wise-dvd-burner-56331.html
Mad Dog... | Answered on Mar 06, 2011
if its just a burner your needin go to flick burner.
Mad Dog... | Answered on Feb 05, 2011
the cd/dvd burner might not be getting enough power
make sure the leads that are attached to your cd/dvd drive have secure connections and are not bad/faulty or just replace them include electrical extension leads
or you might have bad batch of rewritable cd/dvd's
hope this helps
Mad Dog... | Answered on Nov 12, 2010
Have you tried another disc?
If you have a spare disc and after formatting, you fill it with data,
check the output. If it's read, then the problem is with your original disc.
Mad Dog... | Answered on Sep 01, 2010
Mad Dog Multimedia Predator 5.1 DSP 6 Channel Sound Sound Card Logo
12 questions posted
Top Mad Dog Multimedia Computers & Internet Experts
Alun Cox
Marvin
Marvin
Are you a Mad Dog Multimedia Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Mad Dog Multimedia Computers & Internet
Most Popular Question
need drivers predator 5 1 sound card
  • Computers & Internet
