20 Most Recent Samsung UN65ES8000 65" 3D 1080p LED-LCD TV - 16:9 - HDTV 1080p - 240 Questions & Answers
I urge you to update the firmware. (Verify the version to model match)
file is available at
26215485-lkq3pofalwofyawnl3ngt3yc-2-0.pnghttp://www.samsung.com/ca/support/model/UN65ES8000FXZC
The only RISK is the TV should NOT reset/shutdown while performing this update.
So it would be highly recommended to get the firmware update done at the Samsung service centre.
Samsung... | Answered on Jun 09, 2016
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
If blinks continue without any pause, the main board is faulty.
Samsung LE... | Answered on Mar 11, 2015
you will need to replace the leaky capacitors in the power supply circuit. You can locate the faulty capacitors with a visual check. Those that are bulging need to be replaced.
Samsung LE... | Answered on Mar 04, 2015
Most likely the power supply capacitors. you can identify them by their bulging tops.
Samsung LE... | Answered on Jul 24, 2014
Samsung UN65ES8000 65" 3D 1080p LED-LCD TV - 16:9 - HDTV 1080p - 240 Logo
3 questions posted
Jerry Greenberg
Jerry Greenberg
View Most Popular
LE Samsung
  • LE Samsung
Most Popular Question
direct me part most likely causing tv
  • Televison & Video
