20 Most Recent
Brainydeal Elm327 Usb Auto Car Diagnostic Code Reader Scanner - Read Trouble Codes And Check Engine Lights Blue Questions & Answers
Doosan forklift gc25-e5 what need to rea check engine light is on
ON MANY OF THE -5 RANGE OF THE TEIR2 & TEIR3 DOOSAN TRUCKS (ORANGE IN COLOUR) HAVE FLYBY WIRE THROTTLE, YOU CAN USE DIAGNOSTICS TO READ THE CODES BUT THE TRUCK ALLOWS YOU TO READ THE FLASH CODES BY TURNING THE KEY TO THE FIRST POSITION (IGN LIGHTS ON) AND PRESSING THE ACC PEDAL UP AND DOWN FULLY 5 TIMES IN 3 SECONDS AND THE MIL LIGHT WILL FLASH OUT 3 DIGIT CODES UNTIL YOU READ A 2 DIGIT CODE WHICH IS 12 AND THATS THEM RETURNING BACK TO THE START AND THEY WILL REPEAT AGAIN. TO CLEAR THE CODES TURN THE KEY OFF AND BACK ONTO THE FIRST POSITION AND PRESS THE ACC PEDAL UP AND DOWN 10 TIMES IN 5 SECONDS TO CLEAR ALL CODES FROM THE ECU. THERE A LOT OF PHANTOM CODES THAT DOOSANS BEEN CHANGING THE SOFTWARE TO TRY AND ELIMINATE SO IT WOULD MAYBE BE A GOOD IDEA TO HAVE UR SOFTWARE UPGRADED (5MIN JOB). ALSO A LOT OF CODES ARE THROWN UP DUE TO THE WIRING LOOM THAT RUNS OVER THE INLET MANIFOLD THE RIBS ON THE SHEVIN WEAR THE WIRING IN THAT PART OF THE LOOM AND THEY SHORT AND THROW UP CONSTANT CODES. ANY ISSUES WITH CODES JUST CONTACT ME.........
11/28/2014 12:44:13 PM •
Brainydeal...
Answered
on Nov 28, 2014
RE: Vibe USB Turntable Model:
your choice of "Vibe" turntable could have not been worse.
Any serious Vinyl collector would not use such a cheap piece of equipment.
You Get What You Pay For is so very true in this case.
How to identify a genx scanner device for Windows 7
When you have no driver for this Windows version and the former did not work, even in compatibility mode, then try the free program IrfanView. In the File menu first go to Select scanner source. VueScan is also a program supporting many scanners but not free.
