20 Most Recent Insignia 19 in. Widescreen Flat-Panel LCD HDTV/DVD Combo Questions & Answers
You might have to try another antenna. Buying an indoor antenna can be hit or miss so it might take a couple tries to get the right one. In the mean time go to your menu on the T.V. go to channel set up and program the channels using air and see if that helps.
Insignia 19 in.... | Answered on Aug 18, 2015
Check ur tv menu make sure ur tv is it not on a timer setting.And Sleeper mode is not on like 30,60,120.Turn off the tv timer if it on,and the sleeper mode should be off too.
Insignia 19 in.... | Answered on Jun 18, 2011
Are you watching a HD program?
Insignia 19 in.... | Answered on Jun 06, 2011
I had a similar problem with my 42 in Philips LCD HDTV.
Here was the problem. My Power Supply Board had several bad capacitors. I opened my TV (warranty was expired of course) and found four bulged capacitors on the PSB. Many major electronics companies Philips/Magnavox, Sony, Panasonic, and others were sold capacitors that failed in 2-5 years instead of 10-20. The capacitors fail prematurely due to a lack of preservatives. Unfortunately, they were installed in all sorts of devices and cause a wide range of failure problems.
Here are some options for you.
1. Have it fixed by a professional $$$$$$$??????? (Is it under warranty?)
Remember, TVs CONTAIN HIGH VOLTAGE AND CAN KILL YOU! Do this at your own risk.
2. Open your TV and find PSB. (The board that the power cord plugs into) Check for faulty caps. If you find some (bulged or leaking) bad caps replace the entire board. The entire board costs around $250 right now because they are in high demand right now. They can be found online. I would definitely shop around though.
3. Remove and then replace individual faulty caps. This takes some soldering skill.
Caps are inexpensive and if you can take care of it yourself it will save you hundreds.
This may be your problem. If you determine that it might be.
I have a Tip/How TO tutorial on this site that may also help. It gives step by step instructions for replacing caps on PSB #715t2432-2. If this is your board you are in luck. Here is the Link: Fixing the Philips Turns/shuts off on its own problem. I
Insignia 19 in.... | Answered on Dec 17, 2010
Sounds like you have a stuck channel button, either on the remote or TV itself.
Insignia 19 in.... | Answered on Nov 21, 2010
No,will not work,if PAL frequencies signal.NTSC frequencies signal only work in US,Mexico,and Canada.So,sorry no.
Insignia 19 in.... | Answered on Sep 06, 2010
NCP1230 not sure what frequency it is though the numbers on mine were burnt off I am going to buy all three and start in the middle I will update my findings. There were also other things blown on my power supply Q11 600V toshiba mosfet K2843,R60 = 47 ohm ,R61 =470 ohm ,R63 =.33ohm
Insignia 19 in.... | Answered on Jun 02, 2010
that is probly the closed captio is on get to your menu and turned off..
hope that help
Insignia 19 in.... | Answered on Apr 12, 2010
Sorry, but it sounds like the DVD player is just gone. You can attempt to have someone repair it, but with the low cost of new DVD players, it probably isn't worth it.
Insignia 19 in.... | Answered on Jan 10, 2010
A very good question! The acceptable temperatures are very similar for both technologies.
There are two issues to consider here;
1) Storage Range (TV Off Mode). This is generally accepted to be -4 to +120 degrees Fahrenheit before any damage is likely to occur to either technology.
2) Operating range (TV On). This is generally accepted to be 32 to 100 degrees Fahrenheit. The TV should not be operated if the environmental temperature is outside this range.
Obviously there is some slight variation between manufacturers on these ranges but these are broadly accepted norms.
Sony for example have this to say;
"The television can be placed in storage with environmental temperatures between -4 to 140 degrees Fahrenheit (F) and 20-90% Relative Humidity (RH). The recommended temperature for proper operation is between 41°F to 96°F. Proper operation outside of this temperature range cannot be guaranteed."
LCD screens are known to have a poor refresh rate in colder temperatures and the picture is likely to suffer in these conditions so it is worth bearing this in mind.
However there is evidence to suggest at the other end that operating Plasma screens above 80 degrees can shorten the life of the screen.
Its a bit of a trade off - however the main thing to consider here is how you can best control the environmental temperature to stay within these ranges.
If you are in a better position to keep the garage heated to a reasonable temperature in winter then LCD is the best option. If you are able to successfully keep it cool in Summer then Plasma will be better.
Hope this helps with your decision and thanks for using FixYa.
Insignia 19 in.... | Answered on Dec 28, 2009
Try using the RGB component input and see what happens. If it's normal, then you might have a software issue in the set. You'll get the same quality out of RGB as you would HDMI.
Insignia 19 in.... | Answered on Dec 18, 2009
I had the same problem. I used the code 660 and that works fine for power, volume, and stations for my Insignia with the bell remote. Hold tv button till all 4 lights light up and then press 660 # and everything (minus the menu option) should work. I also tried these insignia codes (which might work if this dont.) 659, 573, 570, 405, 245, 456.
Insignia 19 in.... | Answered on May 10, 2009
Insignia 19 in. Widescreen Flat-Panel LCD HDTV/DVD Combo Logo
Popular Tags
43 questions posted
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Insignia Televison & Video
Most Popular Question
hell man tv not turn
  • Televison & Video
