FixYa.com
Danby 12,000 BTU Portable Air Conditioner - Euro Gray
All Products > Danby > Air Conditioners
Problems with Danby 12,000 BTU Portable Air Conditioner - Euro Gray?
Troubleshooting and Support
Solved Problems for Danby 12,000 BTU Portable Air Conditioner - Euro Gray RSS Feed Post a New Problem
power will not turn on
I've had this AC for less than a month. Was working awesome up until tonight. Went to turn it on and the power just...
1 Solution
Getting the room down to temp....
My danby dpac120068 will run for about 5 minutes, drop the temp of the room from the 31 C to 29 C, but then the...
2 Solutions
red light is flashing continuesly
we have a danby 12000 btu,the problem we have is that the AC is not working since the red light is always flashing. both...
4 Solutions
Leaking
Hi, Our Danby AC is leaking water everywhere. This is the 4th year we have run it but it did sit for 2 winters outside...
1 Solution
water is leaking everywhere
There is watr leaking everywhere, not sure where the hose is soppose to run!
1 Solution
room temperature has not changed since...
hi, i just purchased a danby portable air conditioned DPC120068 and have had it operating for almost 3 hours now. when i...
4 Solutions
Trouble setting up the Danby DPAC120068
I'm having a problem setting the stupid thing up! I think I'm not installing the external water tank correctly because...
2 Solutions
View All
Unsolved Support Problems
Unsolved Problems for Danby 12,000 BTU Portable Air Conditioner - Euro Gray RSS Feed Post a New Problem
Danby Portable airconditioner model number...
Purchased end of April worked fine till sat now will not cool aet cooling temp and wont set keeps going to room temp
Post a Solution
snapping or sprak sound
My Danby has worked fine for years but the other day it started making loud spark sound and was shaking . I took the...
Post a Solution
"Direct Drain"
I am a bit cvonfused with what the "Direct Drain" feature does. Right now it is attached to the back of my AC...
Post a Solution
dois-je couper une glissiere pour la bonne...
je n'arrive pas ? faire 36 pouces .,ca obstrue l'?chappement
Post a Solution
External tank connector
The connector to the external tank has broken and I don't think Crazy glue will solve the problem properly. Where can I...
Post a Solution
where to find a manual for this unit?
Hello! I've got this lovely unit that came with no manual (bought second hand). Any idea where I could download or phone...
Post a Solution
how to turn off Denby portable AC's fan?
It seems the fan always on even it reaches the target temperature and compressor stop. That will make a lot of noise. I...
Post a Solution
View All
Tips & Tricks
Post a New Tip
Specifications
Key Features
Warranty Terms - Parts1 year
Warranty Terms - Labor1 year
Product Weight100.3 lbs.
ENERGY STAR QualifiedNo
PortableYes
Product Depth20-1/16"
Product Width17-1/2"
Product Height33-11/16"
Filter TypeMesh
Model NumberDPAC120068
Reservoir Capacity (gal.)0.5 (internal); 3.9 (external)
Coverage (sq. ft.)500
BTUs12,000
Installation TypePortable
Remote ControlYes
Overload ProtectionYes
Danby Contact Information
Main support number1-800-26-DANBY
Email supportconsumers_usa@danby.com
Sponsored Links
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
