Maytag Bravos 7.0 Cu. Ft. SuperSize Capacity Plus Gas Dryer - White
Problems with Maytag Bravos 7.0 Cu. Ft. SuperSize Capacity Plus...?
Ask our Experts
Chat with a Pro
Tell us why
Share your Experience
Do you recommend the
Maytag Bravos 7.0 Cu. Ft. SuperSize...
Troubleshooting and Support
Solved Problems for Maytag Bravos 7.0 Cu. Ft. SuperSize Capacity Plus Gas Dryer - White RSS Feed
View More Results for Maytag Bravos 7.0 Cu. Ft. SuperSize Capacity Plus Gas Dryer - White
Questions and Unsolved Support Problems
Unsolved Problems for Maytag Bravos 7.0 Cu. Ft. SuperSize Capacity Plus Gas Dryer - White RSS Feed
Answer
I have a washer made by Maytag, it is a Bravos I've only had it about 1 year and for the past about... (More)
Answer
Having similar problems. Just started today. Tried the pause/clear as suggested in the manual with... (More)
Answer
our washer flashes "LF" but is getting water.
Answer
i have a maytag bravos washing machine it doesn't do anything it just says F1 what is the problem?... (More)
Answer
Ex. I put in a load, put it on normal (40 minutes) and hit start. The dryer runs...I come back 40 or... (More)
Answer
how to get the bravos washer lid off need to get stuck clothing out between drum and tub
Find a Manual
Maytag Bravos 7.0 Cu. Ft. SuperSize Capacity Plus Gas Dryer - White Manuals & Guides
Sorry. We do not have a manual for this product.
You can...
  • Search for manuals of related products.
  • Ask an Expert to find it!
WikiManual
(Post a New Chapter)
How to Clean a Clothes Dryer Vent
If your dryer vent hasn't been cleaned in the past year or two, it probably needs it. There may even be a bird's nest in there. How do you clean... by wikihow
How to Wire an Electric Dryer
Modern appliances come with separate ground and neutral wires. Generally, this setup is safer, because the current-carrying neutral is not connected... by wikihow
How to Improve the Lifespan of your Clothes Dryer
Most of the problems in a dryer are caused by poor air circulation inside of the dryer. The dryer will suck air from the outside, pass it through the... by wikihow
How to Repair Loose Baffles in Your Dryer Tumbler
Do you hear clanking noises coming from inside of your dryer tumbler? It may be time to replace the dryer baffles. Here is how to check and go about... by wikihow
How to Prevent the Dryer Cord and Terminal Block from Burning Out
Tips on how to prevent the dryer cord and terminal block from burning out. Steps 1. The cause of the dryer cord wires and the terminal block for... by wikihow
Upload Manuals
Tips & How To Guides for the Maytag Bravos 7.0 Cu. Ft. SuperSize Capacity...
Earn cash by writing Tips & How-To's.
It's easy!  (Learn more)
Dryer Repair
General Electric/Hotpoint/RCA dryer repair pix Kenmore/Estate/Roper/Whirlpool repair pix Frigidaire/Westinghouse/Gibson/Kelvinator repair pix... written by TheMobilian
DEAD DRYER
Push the start button and nothing! Ever have that happen? Chances are an air restriction has developed to the point of a possible fire hazard and the... written by TheMobilian
Elite and Duet Dryer Heating Element Replacement
This advice explains how to replace the heating element on Whirlpool Duet, Kenmore Elite and Maytag Epic dryers. 1. UNPLUG the dryer before servicing.... written by jsrock516
When to Buy a New Dryer or Fix Old One?
If your old clothes dryer is not working well, how do you tell if it's time to replace it?Here are some things to check before you set it on the curb... written by smartr10U
New Clothes Dryer vs. Fix the OLD One
If your old clothes dryer isn't working well, how do you tell if it's time to replace it? Here are some things to check before you set it on the curb... written by smartr10U
Dryer Takes Too Long to Dry
This advice is for problems with a dryer that runs and heats, but takes entirely too long to dry. MOST dryer heat related problems are due to poor... written by jsrock516
Dryer Runs, but Does not Heat
This advice is for all ELECTRIC Dryers that have a "No Heat" problem. Symptom: Dryer turns on, drum spins, but you have no heat. Any of the... written by jsrock516
How to Install a Dryer Belt on Kenmore Elite and Whirlpool Duet Dryers
This advice is for dryer belt replacement on most Kenmore Elite and Whirlpool Duet model dryers. If in doubt, please provide me with a complete model... written by jsrock516
I need help with
near zipcode:
Please enter your zipcode
Search
Click here to get instant support from our best Experts!
Top Repair Providers for Maytag Bravos 7.0 Cu. Ft. SuperSize Capacity Plus Gas Dryer...
Nationwide | 877-477-7278 | Website
Washer and Dryer parts delivered overnight nat... Read More
Featured Listing
Nationwide | 8003571234 | Website
Welcome to Action Appliance Repair. We have bee... Read More
Featured Listing
Nationwide | 7606873360 | Website
Washer and Dryer repair specialists. Why hire som... Read More
Nationwide | 312-404-7574 | Website
Our focus will always be to provide top-notch qua... Read More
Ratings for the
Find a Warranty
Specifications for Maytag Bravos 7.0 Cu. Ft. SuperSize Capacity Plus Gas Dryer - White
Key Features
Warranty Terms - Parts
1 year limited
Warranty Terms - Labor
1 year limited
Product Weight
135 lbs.
Color Category
White
Special Order
No
Moisture Sensor
Yes
Drum and Interior Finish
Steel
Control Location
Rear panel
Delayed Start
No
Extra-Delicate Cycle
No
End-of-Cycle Signal
No
Product Depth
28-3/16"
Reversible Door Hinge
Yes
Product Width
27-1/25"
Product Height
44"
Power Source Ratings
240V; 60Hz; 15 or 20 amps
Model Number
MGD6400TQ · MGD6400TB
Depth with Door Open (in.)
51-3/4
Capacity (cu. ft.)
7.0
Power Source
Gas
Stackable
No
Control Type
Analog
Interior Light
No
Energy Star
No
Color
Black
Maytag Contact Information
Main support number1-800-688-9900
Describe your problem:
Top Dryer Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
close
Add to My Products
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
Step 1: Select a category & subcategory
Appliances Cameras Cars Computers Electronics Home Audio TV & Videos Tools
Appliances Cameras Cars Computers Electronics Home Audio TV & Video Tools
Step 2: Select a product and click on add
I can't find my product
select
Cancel
close
Success!
Add another product
Close
close
Save This Product
Enter your email address
We will not share your email. Privacy Policy
I agree to the FixYa Terms of Use
Send to friends
Your name:
Your email:
Your friends email addresses: (e.g. Julie@email.com)
(Separate email adresses with commas)
Message:
Cancel
