20 Most Recent Tomtom RIDER 2nd Edition GPS Questions & Answers
Have you tried to RESET it ? .... either, hold down the power ON/OFF button for a long while ... (e.g. 30 seconds or more) ... until the device starts up (then let go)..... or use a pin (paper clip) to push into the RESET hole at the bottom of the device.
Tomtom RIDER 2nd... | Answered on Jun 03, 2016
press and hold down both buttons on the head set until blue and red lights flash like crazy, then it is in discovery mode and redo the the find device on the tomtom screen
Tomtom RIDER 2nd... | Answered on Jul 17, 2014
Blown voltage regulator that controls the battery
http://compu-sat.co.uk/repairs%20voltage%20overload.html
Tomtom RIDER 2nd... | Answered on Mar 25, 2014
You should be fine...
Tomtom RIDER 2nd... | Answered on Jul 22, 2011
Hi
I believe you do this in the tom tom home software, this is avalible here
Hope this helps
Tomtom RIDER 2nd... | Answered on Mar 07, 2011
Reset the unit by pressing the small pin hole button. Do this when the unit is on. let it reboot by itself and try again to pair ur phone/blutooth.
Hope this helps. let me know if not.
Tomtom RIDER 2nd... | Answered on Aug 12, 2010
Open the compartment on the bottom of your TOM TOM RIDER and bellow the memory card slot there is a small hole and with a needle insert on it and bingo the unit shuts-off.
Tomtom RIDER 2nd... | Answered on Feb 09, 2010
Here is the link for additional information about your TomTom and Bluetooth:
http://bit.ly/cJ61IB
Tomtom RIDER 2nd... | Answered on Feb 04, 2010
need to change ouput settings, to either internal speaker or audio out if you can connect it to your car audio.
Tomtom RIDER 2nd... | Answered on Sep 04, 2009
Put two pieces of tape on the bit of the unit that slides onto the bike mount thus bringing the unit closer to the pins. Worked for me.
Mike
Tomtom RIDER 2nd... | Answered on Jul 31, 2009
The animation is telling you to insert a data card, which should have come with the device. If you have already inserted the data card (make sure there isn't a blank in the slot) then the unit is faulty and needs to be returned.
Tomtom RIDER 2nd... | Answered on May 17, 2009
Forget TomTom. Go buy this one
http://www.wunderlichamerica.com/mm5/merchant.mvc?Screen=PROD&Store_Code=WA&Product_Code=8600880&Category_Code=
I talked to TomTom multiple times on the phone and had same problem but finally found this. It's better quality and it's available.
Tomtom RIDER 2nd... | Answered on Apr 15, 2009
Under riders seat or under the tank there is a White/blue (+) and Black/Yellow (-) max current is 10 amps
You can wire it like this
red wire from unit to White/blue on bike
black wire from unit to any ground body ect or to the Black/Yellow
This can also be accomplished by simply adding a rv type lighter socket with a mounting bracket and rubber plug similar to this eacb0ab.jpg
and then wire the wire the tom tom to a cigarette plug adapter like this 73f0ffb.jpg
Very easy to do and simple
Let me know if you need anything else .
Tomtom RIDER 2nd... | Answered on Apr 02, 2009
The tomtom is made so you can only receave calls when you are moveing. you can't call out.
Tomtom RIDER 2nd... | Answered on Jul 31, 2008
it can be lots of cause. due to database error. connection issue. or battery problem. better connect with a technician to solve it/
Tomtom GPS | Answered on Sep 10, 2019
i had tried once they take so much longer time . its so irritating better call a local tecnician for better and quick response
Tomtom RIDER 2nd Edition GPS Logo
28 questions posted
Top Tomtom GPS Experts
LP
k24674
Marvin
Marvin
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
View Most Popular
Tomtom GPS
  • Tomtom GPS
Most Popular Question
use tomtom additional bluetooth headset
  • GPS
