The Water Shut-Off Controller can be linked to HOMEheartbeat water sensors (HHBWATERSNSR) to automatically shut off your house's main water linein the event of a water leak. Simply place Water Sensors in high-riskareas for water damage. Then install your Water Shut-Off Controller onyour main water line and setup the unit to turn off if a Water Sensorbecomes wet. Then, when the icemaker malfunctions or the toiletoverflows your Water Sensor will become wet and your main water linewill close, minimizing the costly water damage.
NOTICE! This product requires installation of, and will only work with a HOMEheartbeat Ball Valve. Ball Valve installation may require professional plumbing assistance.
Important Note: Use of this product requires the purchase of the HOMEheartbeat Starter Pack
Wooden flooring is known for its elegant look. It creates a warm ambience inside your home. Hardwood floors are elements of d?cor themselves, which are available in many different types and colours. Its durability will ensure a good interior investment while providing aesthetics to your home.
Like Steve stated. I would add to use a rust-converting primer (the type that converts surface rust into an invert primer, stopping all future rusting).
As this is only occurring in the left corner, I'd try to determine exactly where the water is coming from (that's causing the damage). I suppose it could be condensation if the unit is over ten years old, but it also possible that a connection slightly loose or worn.
Aug. 22, 2019 - Night vision doesn't work, can't record anything, or infrared is not working. Can't connect to NVR security camera on my iPhone/iPad. 24/7 ...
If the Soliom camera does not work properly To Illustrate, as the lights are not on in dark at nights, it is likely a cable problem, and it will cause no video and no image recording at night. You can use another cable to connect the camera to see if the problem is solved.
Question edited for clarity. Delete surplus words and fix the rest.
From the manual on Page 24
7. Forget password Solutions: Method 1: Please use password resetting email to get password. Method 2: Please contact technical engineer to reset password.
Or just buy another one
Amazonhttps://www.amazon.com > ...
[Powerful 5-in-1 DVR & 5MP HD Stream]-- The hybrid digital video recorder works with up to 5MP TVI, AHD, CVI, CVBS analog and up to 2MP IP security cameras. · [H ...
Rating: 3.8 · 331 reviews · US$69.99 · In stock
Or ask them direct
It may have this silent option in either choice for volume or melody. My doorbell has numbered buttons that need to be pressed together with the button to open the door, in order to access these functions.
Another thought is that a battery needs to be replaced.
Question moved from Photo Cameras to Home Security Category.
I would caution hiding transformers under a bed because they can get hot, overheat fail and cause a fire. You can certainly use an extension power bar with a a circuit overload breaker in it, but move it somewhere other than under the bed. You could even fix the power bar to the wall a bit higher up and make use of it as long as your daughter knows the dangers of electricity.
https://www.google.com/search?q=DSC+PTD1640U+transformerhttps://www.google.com/search?q=power+bar+with+breaker
Presume this is a Security Camera system as opposed to a Sony HandyCam, so I moved it to the Home Security category from 'Power Computers'.
The system has lost the feed to the camera because the power flicker was a power disconnect. You should have it on a backup UPS backup.
You need to reinstall the camera feeds.
Full 'make model (what is is)' in all questions first 3 words.
Google
make model manual
Press the reset button: Using a small tool like a toothpick or paperclip, press and hold the reset button for a few seconds until the DVR resets. This will restore the DVR to its factory settings, including the default password
