20 Most Recent
Maytag 30" Built-In Electric Cooktop - Black Questions & Answers
When using a burner and turning a knob the cooktop
is this a common occurance or a one time thing? if it's common the cooktop might not be wired to the supply correctly causing th phases to be unbalanced drawing too much current from one phase instead of both evenly ish. you'd have to meter it out to see but if you aren't knowledgable with electrical stuff get an electrician to check it if it only happened the one time and isn't anymore probably don't need to worry about it
Broken glass top
Hello and sorry to read about your problem.
You might want to think about a new unit. a glass replacement, can run $600.00 to $900.. and more. and that's just for the glass....
I tried to help you.Please help me and vote/rate my response thanks
New Maytag MGC7430 gas cooktop leaks gas when lit
First it could be leaking from the control knob when it is on . There could be a leak at the base off the burner letting out gas or on the burner line . You need to get back on to your installer or where you purchased the cook top . This basic gas fitting leak detection .
The electronic lighter will not quit clicking.
Hello, Thank You for using FixYa. I will be helping you today. Did you clean the cook top or spill something? If the switches get wet they will click untill it drys out. If not then one of the switches failed and would need to be replaced. Its the switch that sits on the burner valve.
Thank You and please ACCEPT my answer and Rate my answer if it was helpful..
My electric igniter keeps sparking
Hello, Did you clean the cooktop recently? Sometimes water or cleaner can get into the spark switch causing it to spark untill it dries out. The same if a boiling pot spills. If none of those happened one of the burner switches is bad.
