I have a GE wall oven not working at all-electronic display works, will not heat, no broiler I think...
(More)
I have a GE wall oven not working at all-electronic display works, will not heat, no broiler I think it is the ignitor, but not sure Had it fixed once before but cant find invoice for repair
I have a GE 30" oven, with a new computer board; the oven is around 10 years old, and they...
(More)
I have a GE 30" oven, with a new computer board; the oven is around 10 years old, and they changed the stem size on the thermostat control, so the knob doesn't fit. Where can I get a 3/8 to 1/4 adapter for a shaft with a flat? They used to supply one with the computer, but not anymore... Thanks.
Does the GE 24? Gas Built-In Oven JGRP17 require a flue to be installed to the outside. I am...
(More)
Does the GE 24? Gas Built-In Oven JGRP17 require a flue to be installed to the outside. I am replacing an older oven that has a flue installed through the roof to the outside. There is no mention of a flue in the installation instructions but there is a small vent fan on top of the oven. Thank you
Model #JGRP17BEW4BB wall oven display F7 code, Oven will try to start on it own, will beep and flash...
(More)
Model #JGRP17BEW4BB wall oven display F7 code, Oven will try to start on it own, will beep and flash start
I have GE 24" Built-In gas oven, Model JGRP17BW38B Serial D7608522R, 120VAC, 60HZ. I need the...
(More)
I have GE 24" Built-In gas oven, Model JGRP17BW38B Serial D7608522R, 120VAC, 60HZ. I need the squematic wiring so I can make the connection wire to lead terminals control. The old control was replaced by one new and the squematic cables connection control was not made. The new control is TORISAN Thermostat model RGB04XP015CN-AB and the replaced was GE WB27T10267. I would appreciate help me. F Fernandez
I JUST CALLED FRIGIDAIRE AND GOT INSTRUCTIONS FOR SELF CLEANING: 1. TAKE OUT THE RACKS UNLESS YOU DON'T MIND THEM TARNISHING 2. TURN THE...
written by NATALIENATAL
Equipment is Whirlpool double oven RBD305PDS14 built-in. After a very stormy summer 2007, I thought a power surge may have zapped the control...
written by babrown
Before you bake something, your oven needs to be heated to the proper temperature. While it takes only a few seconds to turn on your oven, it can take...
by wikihow
Honest, Dependable, Available & Professional!
Appliance Parts Supply! We Ship Nationwide. Our Phones Answered From 7 AM - 9 PM CST Mon - Sat.
Over 30 Years Experience!
972-859-0929 - Call us NOW!
www.accurate-appliance-service.com
